Thread Tools |
This thread is privately moderated by scousethief, who may elect to delete unwanted replies. |
Eachine ROTG01 Pro UVC OTG 5.8G 150CH Full Channel FPV Receiver W/Audio For Android S
https://www.banggood.com/Eachine-ROTG01-Pro-UVC-OTG-5_8G-150CH-Full-Channel-FPV-Receiver-WAudio-For-Android-Smartphone-p-1347396.html
Eachine ROTG01 Pro UVC receiver is upgraded with audio,and two buttons which make you search the frequency up or down,also included 2 different cables for Type-C and Micro USB, and receiver sensitivity is more stable than the old version. It is a new receiver that you can connect to your smart phone directly instead of heavy monitor and good for those who feel dizzy when wear FPV goggles. It has low latency around 100ms. 150CH auto search allows to cover all 5.8G frequency bands. One-screen display and double-screen display are switchable. Parameter : Brand Eachine Model ROTG01 Pro Name UVC OTG FPV Receiver Channel 150CH Frequency Range 5645~5945 Sensitivity -90dBm Working Current 200mA/5V Power Supply 5V(by smart phone) Operating Temperature -10~60℃ Connector RP-SMA Female Weight About 28g Size 61*33*0.9 mm Color Black/White Resolution 640*480 Please note:This Reciever only suits for Android phone that support UVC and make sure your phone can work with OTG connector. How to check my phone support UVC: https://drive.google.com/open?id=0Bz...jNGZ25EdTlSLWs APP Download: http://files.banggood.com/2016/12/Go....2.1pakage.apk https://drive.google.com/open?id=0Bz...HI4M09QS0lxdEU Here's the phone list support this receiver that we have test . Sumsung: S3(I9300,I9308), S4(I9500,I9507V, I9508, S5, S6, S6 edge+, S7edge, NOTE3, NOTE4, NOTE5, A5100, A8000, ON7, P600, N7100, N5100, Tab S2..) OPPO: A31, A31C, A33, A51, A53, A33M, A51, A53, A5M, N3, FIND7, R7005, R7007, 3007, R2017, R8000, R8205, R8207, R7SM, R7 PLUS, R9 PLUS, ect.. XIAOMI: XIAOMI 3, XIAOMI 4, XIAOMI 4C, XIAOMI5, XIAOMI pad, XIAOMI Red Note, XIAOMI Red Note3, ect... HUAWEI: MATE8, C199,Honor8 LG: GPRO2,G3,NEXUS5,L24,GPAD8.3, ect.. MOTOROLA: XPRO,NEXUS6,MOTO E,MZ617,ect.. SONY: Z1,Z2,Z3,C3,SGP321,ect.. Note: There are 2 same connecters on USB cable, but in different function. One side is special for mobile, the other is special for receiver. Please connect them correctly. If it doesn't work , please try to plug them in reverse. Pacakge Included: 1 x Eachine ROTG01 Pro 5.8G 150CH Mobile Receiver 1 x RP-SMA Antenna 2 x USB Cable The receiver arrived in a well packed "jiffy bag" but it is protected very securely by this quite nice metal case. The entire contents of the tin are a micro usb to micro usb cables ( which are bloody great ! im always looking for an adapter )and a type "C" cable , a standard di-pole antenna and the ROTG01 usb receiver itself. The controls for the ROTG01 are nice and simple............. 2 buttons............Search frequency up and search frequency down... even i cant mess this method of channel finding up...or down... On the bottom of the receiver are 2 ports, one for the micro USB and one that looks like a typical Uart connector , probably for software updates. The internal board is a single circuit board with a typical receiver soldered in place. On the rear there is an open set of pads for a second receiver which would allow DIVERSITY ! There are two main chips on the rear which i assume are for controlling the search and for basic image coding. Here is a link to the video decoding processor AMT630A Data sheet The chip marked V399 is also a video encoder/decoder and seems to be a carry over from the generic EasyCap USB Dongles, here is a link to the Datasheet/Manual for this USB 2 camera controller... MANUAL But basically it is capable of 30FPS at lower resolutions which should be fine for viewing our FPV cameras. |
what this component name and size sir ?
Thread Tools | |
Similar Threads | |||||
New Product | Eachine ROTG02 UVC 5.8G 150CH Diversity FPV Receiver. | rank | FPV Equipment | 85 | Sep 07, 2022 06:20 AM |
New Product | Eachine ROTG01 Pro UVC OTG 5.8G 150CH Full Channel FPV Receiver - Free Reviewing | BGKevin | FPV Equipment | 41 | Nov 19, 2018 01:20 PM |
Question | EACHINE EF-01 5.8G 40CH 25MW Video Transmitter VTX and RCmall 5.8G UVC Receiver Mini | hamza.ali | FPV Talk | 0 | Aug 10, 2018 03:21 PM |
Discussion | 5.8G Mini FPV Receiver UVC Video Downlink OTG | harrysvr | FPV Equipment | 33 | May 15, 2018 05:31 AM |
Discussion | FPV Goggle+5.8G OTG FPV Receiver UVC Capture Card Apm Pix for Android Mobile Phone | scousethief | Banggood.com | 0 | Mar 09, 2017 01:44 PM |
