Sep 17, 2018, 05:38 PM
Edgar Perez's Avatar
Firmware Update XPS24 - Steps?
Hello
I was unsuccessful on my attempts to update the firmware of the XPS24. Need to confirm the steps.
1) Get the software http://www.xtremepowersystems.net/xdp/xdp_setup.exe
2) Install the software in my PC
3) Connect the XDP USB device to my PC.
4) Set the XPS24 to the programming mode.
5) Connect the USB device to the XPS24. Where does it goes?
6) Run the XDP.EXE program.
At some point I will need the "X24-updater19.exe", but not sure in what step...?
Appreciate some guidance.
Regards
Sep 17, 2018, 10:32 PM
First, you might want to check to see what version of firmware is installed in the X24. Unless you got the X24 long ago, you probably already have the latest version.
You don't use the XDP hardware or software with the X24. That is for our other products. You would only run the X24 updater using our SerialLink. You need to plug the cable from the SerialLink into the MATCH power input.
Mini-HowTo Step by step guide for Flashing Turnigy 400W v2 with Open-Source Firmware RadMulRot Batteries and Chargers 11 Feb 21, 2018 02:42 AM
Discussion Flash firmware for internal modules for Taranis X9D Plus FIRMWARE UPDATE ERROR baptist FrSky 2 Jan 25, 2016 04:58 AM
Mini-HowTo Update Firmware for Devo TX - Import/Export Devo TX Models - Update Devo RX Firmware Tom Z Micro Helis 22 Jun 28, 2015 12:20 AM
