Sep 16, 2018, 11:57 AM
Garland
Ghia's Avatar
Nano B the ppm port? Its not clear in nano manual
Nano manual doesn't say which servo port is for ppm stream. Im trying to hook a nano and spartan heli FBL system together. I think port B would be ppm only...the other nano ports are clearly servo ports. I have never used ppm anything yet pwm normal servo only so far
Sep 16, 2018, 04:19 PM
Build more, websurf less
FlyingW's Avatar
Ghia,
After configuring the receiver to output PPM, it will put a positive PPM signal on servo outputs 1,3, and 5, and a negative PPM signal on servo outputs 2, 4, and 6.
Good luck,
Paul
Sep 16, 2018, 04:34 PM
The manual does state the above info. The B port is only used as an input. It can never be an output.
Sep 16, 2018, 04:46 PM
Garland
Ghia's Avatar
Ok yes it does say 1,3,5 is positive ppm and 2,4,6 is neg ppm....Im not hip to what I do with that info. How is that single wire between FBL and RX? Thanks
I got nano to ppm only led on solid. Now what? My FBL system expects a single wire between them.
Or I got to tap into the positive and neg ppm stream together to get my channels?? So with three plugs one into FBL...one into nano channel 1... last into nano channel 2. There is such a funky cable includied with my FBL I got that right?
Sep 16, 2018, 05:08 PM
Garland
Ghia's Avatar
Hmm I might be out of luck on this FBL sys wants just one RX port for ppm not positive and neg ppm ports on RX
Sep 16, 2018, 06:03 PM
FlyingW's Avatar
I'll bet you could connect a single lead from servo output 2 on the Nano to the PPM in on the flight controller.
You will likely need a common ground as well. If both the receiver and the flight controller are using the same battery and ground the single PPM lead should work.
Sep 16, 2018, 09:10 PM
You just need a single cable (3 wires) from the Vortex to the Nano. You could use the cable shown and plug all 3 plugs into the Nano, but a single cable with power/ground/signal would be the easiest.
Sep 16, 2018, 10:38 PM
Garland
Ghia's Avatar
Thanks guys! So a normal servo lead which I also have, plugged into channel 1 for the positive ppm stream will get me all my channels?
Question why neg and positive ppm? FBL sys has no mention of neg and positive ppm or which it wants
Sep 17, 2018, 08:17 AM
FlyingW's Avatar
Yes, all control channels are included in the single PPM output wire - that is, as many channels as your transmitter is putting in. The flight controller then sorts the PPM stream into the individual channels.
Over the years the PPM protocol was implemented by vendors using either the positive and negative conventions. If your flight controller doesn't work with one, it will likely work with the other.
Cool It may not be flight of the year, but its got a train in it ;) ENJOY! LegendFPV Multirotor Drone Talk 0 Dec 15, 2017 07:43 PM
Cool It may not be flight of the year, but its got a train in it ;) ENJOY! LegendFPV FPV Talk 0 Dec 15, 2017 07:42 PM
Help! D4R-II to Flip32 via PPM works fine while in Cleanflight Config, but not without it day o Multirotor Drone Electronics 5 Sep 30, 2016 11:42 PM
Discussion G W Bush legacy seems to be unfolding in print, and its not kind AA5BY Life, The Universe, and Politics 80 Nov 19, 2015 03:08 AM
Discussion Just to clarify about setting gains...not that clear to me in manual dzwiss Aerial Photography 3 Apr 07, 2012 01:32 PM
