Jun 19, 2019, 05:12 PM
Build straight - Fly twisty
Whiskers's Avatar
Originally Posted by birdofplay
Ya don't have to fly this model !
You simply give it a little power and PARK it in the sky !
You didn't have too much UP trim, you had too much power ;^}
Slowly is the Name and Slowly is the Game !
Rocking ? ! Rocking ! ?
That actually just Pendulum Effect ;^}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}
There's no doubt that you are correct that I had too much power on.
Please bear in mind that this was the first time in my long, long life that I encountered a model that likes to fly on about 1/8 throttle or less.
It was the test flight. I had to learn stuff.
It did fly better after a little down trim, as I knew it would because I was holding on a little 'down' on the stick. I think the elevator was initially rigged fractionally 'up.'
On a flight after the ones depicted in the video the elevator servo decided to go no strike. This gave me some experience of your 'rudder and throttle only' setup. It did not end elegantly, but did not result in any damage. If I remember correctly the servo is a 'high hours' unit from a discarded plane. Ah well...
Jun 19, 2019, 05:58 PM
Retired CAD guy
birdofplay's Avatar
After all my years of "breaking in" new models I have a drawer full of those same servos !
Not even counting all those old Futaba std 133 class servos left over from the 80-'s and 90's
I did not intend to be critical of your flying.
Just offering some suggestions for adding this "type" to your ticket ;>}
Glad to see it flying nonetheless.
Incidents with this model ,at it's exceptionally low speed ,
don't usually result in damage.
I did take some exception to all the clutter at your choosen flying veneue.
Light poles , Soccer goals et al ;^}
Now you can decorate it in Caloundra TEAM Colors,
which appears to be Blue and White.
Jun 24, 2019, 02:04 AM
Whiskers's Avatar
Cows Should Fly
OK. I've upgraded the landing gear, replaced the old TowerPro elevator servo with a used HK 9g unit, given the motor a bit of side-thrust and a bit more down-thrust.
Also, in a fit of insanity, I made a cow pilot.
Jun 24, 2019, 07:43 AM
Retired CAD guy
birdofplay's Avatar
Now that's the spirit !
Now if you can just stay away from all those Goals and Poles and Fences !
Discussion hobbyist or sites that build for me Ciossonno Vendor Talk 0 May 18, 2016 05:38 PM
Discussion Help me find suitable parts for my build thulfiqar Beginner Multirotor Drones 9 Mar 12, 2016 12:19 AM
Discussion Good simulator program for aircraft w/ unusual sideforce characteristics? aeronaut999 Modeling Science 25 Feb 09, 2016 12:53 AM
Cool unusual ME 262 mistairjoe Scale Kit/Scratch Built 17 Jan 16, 2016 08:46 AM
Discussion Looking for someone to cut me an unusual wing core aeronaut999 Slope 2 Apr 24, 2013 05:03 PM
