This thread is privately moderated by Randy Reynolds, who may elect to delete unwanted replies.
Sep 13, 2018, 06:33 PM
Trader Rating: 10
Randy Reynolds's Avatar
$235.00 USD
Buyer pays shipping
Sold
Powerline 1015 motor and Stuff
This is an excellent F5J motor that weighs 75 grams (as I recall) I had it fitted to an Explorer 2 F5J but at our 7000' altitude it didn't have enough thrust when the wind came up. It's a really good motor often used in F5J which was my original intent. This motor has a 5mm gearbox shaft and so I bought a Georgi Mirov Spinner and prop(s). The 17/7 prop is beautiful and really fits closely to the fuse but again not a good choice up here where the air is thin. Bought new all of this is over $300. Motor has about 20 flights on it and the spinner and prop much less. Motor leads are original length.
My email is: carranrey@gmail.com
Sep 14, 2018, 07:16 AM
Trader Rating: 95
Wayne Wimbish
wdwimbish's Avatar
Randy,
What's the bolt pattern on the gearbox? I have a mount for a P29 gearbox. Will it fit?
Wayne
Latest blog entry: Paying for Purchases by PayPal
Sep 14, 2018, 09:42 AM
pnc
Trader Rating: 44
pnc
pnc's Avatar
No Wayne a P29 Mount will not fit the bolt pattern is 4 on 17mm on the powerline but you can change mounts pretty easy
Pete
Sep 14, 2018, 09:43 AM
Trader Rating: 6
in awe of glide...
Kirkerik's Avatar
me too w the p29^^
4 holes on 17mm dia circle for the powerline motors
via: https://www.hyperflight.co.uk/produc...erline-gearbox
Could possibly adapt it though, Wayne!
Sep 14, 2018, 10:15 AM
Trader Rating: 10
What I did on my Xplorer was to cut off the PNC Powerline mount which took 1/2" off the fuse and install a new PNC mount for the P29 which fit my Neu 1102 motor. Hate to have a perfectly good PNC mount go to waste but it all worked fine.
Sep 14, 2018, 01:31 PM
pnc
Trader Rating: 44
pnc
pnc's Avatar
I don't mean to barge in on your thread here a p-29 mount is deep a power line Mount is shallow looking from the front it would be pretty hard to make a p29 Mount work for a powerline motor.
To remove a PNC mount you can put a big bolt in from the back side with the nut on the front and heat up the bolt until the J-B Weld get soft and you can pull it out and save your mount
Sep 14, 2018, 02:37 PM
Trader Rating: 95
Wayne Wimbish
wdwimbish's Avatar
Randy, I am interested. Will you throw in the pnc powwrline mount for the same price?
Wayne
Sep 14, 2018, 03:41 PM
Trader Rating: 10
I do stilll have the Powerline mount however it is encapsulated in the front 1/2" of the Fuse. It was glued in with JB Weld and so I suppose it is possible to heat it up to soften the JB Weld and remove it. I didn't think to use the bolt suggestion at the time.
So I will include it with the motor, GM Spinner and prop....deal?
Randy
Sep 14, 2018, 05:24 PM
Trader Rating: 95
Wayne Wimbish
wdwimbish's Avatar
Randy,
Sorry but I think I am going to have to pass. After a little more research I have concluded that I would need a 1025 Powerline if I were to go that way. I am expecting an AUW of 2000g+ and the 1015 just wouldn't have enough oomph cut it. I would just end up in the same boat you are in now.
Thanks, Wayne
Sep 14, 2018, 05:45 PM
Trader Rating: 10
I'm no expert but 2000g would need at least a Neu 1105 or 1107. I don't know that a 1025 would haul that up the way you want but others would know.
Good luck! Randy
Sep 14, 2018, 06:59 PM
Trader Rating: 28
Original Bloody Spadder
proppy jon's Avatar
1015
If your open to take a offer I am interested is it a 3 cell motor or 2 cell motor
Sep 14, 2018, 07:54 PM
Trader Rating: 10
It is a three cell motor.
Wanted Powerline 1025 motor foxcraft Aircraft - Sailplanes (FS/W) 0 Sep 04, 2017 03:56 PM
For Sale Powerline 1015 w/ PNC 32mm motor mount IBWALT Aircraft - Electric - Power Systems (FS/W) 0 Feb 21, 2017 03:16 PM
Discussion Mega motor vs Powerline 1025 dodgykebab Electric Sailplanes 9 Jan 12, 2017 08:46 PM
Wanted Powerline motor bandmcurry Aircraft - Sailplanes (FS/W) 0 Feb 16, 2016 05:59 PM
For Sale Powerline 1025 Motor jtlsf5 Aircraft - Sailplanes (FS/W) 2 Jan 25, 2016 05:18 PM
