Sep 13, 2018, 04:49 PM
ace4rc's Avatar
Help!
RPM numbers, how do I?
How do I get the battery voltage on the Dashboard? The drop down menu does not show a Rx voltage like it does for live mode without the dashboard.
Also, in the bottom right corner there is the word hooting, see pic, why is it there and or what does it mean?
Sep 14, 2018, 09:13 AM
JohnET's Avatar
Hello,
I think that is trying to show "See Troubleshooting". To fix it, try a firmware re-flash and a run of the "Seagull Wireless Dashboard Setup Wizard". The other option would be to display "PkV" in that fourth display spot and that message should disappear.
You may want to try "Pack Voltage" on the eLogger and not "RxV". If you are not able to get it working correctly, please open a support ticket.
Regards, John
Sep 14, 2018, 11:29 AM
ace4rc's Avatar
Thanks John but there is no pack voltage in the drop down menu. This morning I tried the electric associated options and got the PkV on the dashboard by using the electric motor voltage.
Sep 16, 2018, 02:36 PM
ace4rc's Avatar
Now I would like to know if the rpm gauge can be changed, it is showing up to 35000 rpm. I would like it to be much lower, maybe max at 7000.
Sep 17, 2018, 02:02 PM
JohnET's Avatar
Hello,
I am not sure which gauge your are talking about specifically however in the graph you can adjust it but the gauge itself in the software is not manually adjustable. It should scale automatically. If it shows something abnormally high, it could be picking up spurious reading during bootup etc which could set it higher than normal operating parameters. If you are unable to get it working correctly please open a support ticket.
Regards, John
Help! Frsky Fsd Dashboard Altitude Fail Karli1972 FlySky 2 Dec 05, 2016 05:34 AM
Discussion Dashboard Log Futaba Fabweb Radios 0 Sep 04, 2016 12:29 PM
