Jul 23, 2019, 11:17 PM
If it flies, I can crash it.
rocketsled666's Avatar
I got mine in the fall last year. Sat in my workshop all winter. When I went to take it out this spring, I grabbed it by the tail to pick it up and the stab came apart. A little glue took care of it. But if I'd maidened it when I got it I might not have noticed. Seems common enough of a problem, it's best to assume yours is a bit short of adhesive in this area and "enhance" it.
Jul 24, 2019, 06:20 AM
Flying Low
cbarnes0061's Avatar
Before work maiden didn't go quite as planned. Plane flys great and here are my thoughts. Decent power on 3S so can't wait to see it on 4S. Flew slightly nose heavy as I expected for first flight with battery placement. Stalls are nice and gentle. KE had no coupling for me at all. I do think it needs more control throw all around and I will be adjusting my radio to match what I think it needs. Rolls are pretty quick but could be quicker and without more throws in the tail I couldn't get it to do a nice snap like I would like and like I have seen it do in videos. Could also be the forward CG that is affecting it a bit.
Now to the rough part. Bringing it in to land did a couple approaches to feel out the plane and it does need a little speed. Make a nice smooth touchdown but did not see the bigger rock in my path. Rock caught the right gear and basically caused the plane to do a high speed ground loop that when the gear leg bent and folded up the plane then cartwheeled causing the other damage. Will repair the gear at work today and so long as the prop adapter isn't bent then it will fly again soon. I'm thinking though the wheel pants may have to come off in favor of some slightly bigger wheels for when flying off of the grass runway at my club field.
Jul 24, 2019, 11:54 AM
If it Works, You Better Fix It
VelocityRC's Avatar
Originally Posted by Brett_N
FYI, the horizontal stab WILL EVENTUALLY come apart if you don't glue it.
In fact, mine came apart even glued - the stupid plastic Male/Female "D" connector broke right off.
Am I missing something ? Is there something additional you guys are recommending over and above what's in the instructions ? The image notes say a drop of CA but I kinda soaked mine.
Bill S.
Jul 24, 2019, 01:21 PM
blissinindy
Bill S.
I was thinking of using foam tac so I could completely disassemble if ever needed. I figure it works for foam hinges on control surfaces on larger, 1.2m class birds - think killer-planes recommendations for example ...
Thoughts?
Jul 24, 2019, 01:35 PM
Flying Low
I just pressed them in place then went around the edge with bob smith foam safe thin CA to wick in. Seems plenty tight to me even after cartwheeling the plane this morning.
Jul 24, 2019, 05:17 PM
Flying Low
well that part is repaired at least.
Jul 24, 2019, 11:43 PM
Helique's Avatar
Nice job on the gear! Man, your runway sucks... almost as bad as where I fly. I ended up taking the wheel pants off of all my planes and put bigger wheels on to handle the rough terrain.
Jul 25, 2019, 05:46 AM
Flying Low
Yeah it’s not my club field though. Just a park I stop at to fly on my way home from work sometimes. Normally use the field that is used as a football field but the grass hasn’t been cut so I choose the parking lot.
Jul 27, 2019, 01:42 AM
Fly Planes, Be Happy 😜
ooOoo's Avatar
The new gear you made looks nice!!!
Jul 27, 2019, 01:44 AM
ooOoo's Avatar
I love flying my Pitts but I have problems landing it. It comes a lot faster than I'd like. If I try slowing down more it will fall out of the sky. The rollout is crazy long on the petromat but not as bad on the grass.
Anybody else think it comes in too hot?
Jul 27, 2019, 06:02 AM
Flying Low
I redeemed myself this morning with mine. Yes it lands hot. I'm sure on grass it will be fine but on the hard packed drive this morning it rolled out a good 35-40 feet once it touched down.
Jul 27, 2019, 06:04 AM
Flying Low
Thanks. Also to note your previous question on battery placement I moved mine further aft this morning. I now have it where the front strap on the battery tray is just barely catching the front of the battery. Plus I cranked the endpoints up and swapped out the servo arm on the elevator servo to get more throw. Really livened the plane up.
Jul 27, 2019, 12:04 PM
ooOoo's Avatar
I may just take off from the petromat and land on the grass. All of the grass landings I've done have been great.
Your battery placement sounds a lot closer to where mine is too. I removed the front strap since I didn't use it. I also glued a piece of velcro to the plastic tray to keep the battery from sliding out from under the strap. Battery weight could make a small difference in battery placement; mine weight ~200 grams.
Jul 27, 2019, 12:08 PM
ooOoo's Avatar
Idk how others do things, but I have read a few cases of the plastic tray sliding out during flight. After I'm done flying the plane I will just set the tray in the battery compartment and NOT slide it in the receiver or click it in. Just toss it in the open fuse. I figure it may help prevent the clicking bumps from wearing out and I'm not sure if they have pressure on them while the tray is inserted or not.
Jul 27, 2019, 12:14 PM
ooOoo's Avatar
Such a sexy plane! Currently flown with my hybrid TaraniSpektrum radio, but I'm thinking about setting it up on my Taranis instead and use a module since the AS3X receiver works so well.
New Product UMX Pitts S-1S BNF Basic with AS3X Technology by E-flite Diesel6401 Micro Ready-to-Fly 11716 Jan 14, 2020 11:29 PM
Discussion New Cherokee 1.3m BNF Basic with AS3X and SAFE Select Capt Ed Electric Plane Talk 1464 Jan 06, 2020 05:51 PM
News Parkzone F4F Wildcat 1.0m BNF Basic with AS3X and SAFE Select Jason Cole Electric Warbirds 152 Mar 20, 2019 03:20 PM
Review Clipped Wing Cub 1.2m BNF Basic with AS3X and SAFE Select Review Hiflyer Parkflyers 14 Jan 22, 2019 01:57 PM
