Hitec D85MG Micro Servo
Here is a new micro servo from the fine folks at Hitech.
D85MG Micro Servo
We are excited to introduce our metal gear, micro D85MG. Engineered with our state-of-the-art D-Series technology, this “micro but mighty” servo is an upgrade from the popular HS-5085MG. With soft-start enabled circuitry, 4096 high-resolution and a long-life potentiometer, the D85MG allows for smooth and decisive movement and accuracy. Programmable application-specific parameters provide the ultimate in maximum servo performance.
!Features:
  • Durable Metal Gears
  • Advanced Programmability
  • High-Resolution, 32-Bit Digital Circuitry with 12-Bit ADC
  • 1M Cycle, Long-Life Potentionmeter
  • 24-Tooth Output Shaft
Highlights of the D-Series Servos Manufactured by Hitec RCD (1 min 56 sec)
Performance Specifications
  • Operating Voltage Range (Volts DC) 4.8V ~ 6.0V
  • Speed (Second @ 60°)0.17 ~ 0.13
  • Maximum Torque Range (oz. / in.) 50 ~ 60
  • Maximum Torque Range (kg. / cm.) 3.6 ~ 4.3
  • Current Draw at Idle 3 mA
  • No Load Operating Current Draw 290 mAh
  • Stall Current Draw 2,150 mA
  • Dead Band Width 2 µs
!Physical Specifications
  • Dimensions (Inches) 1.14 x 0.51 x 1.18
  • Dimensions (Metric) 29.0 x 13.0 x 30.0
  • Weight (Ounces) 0.77
  • Weight (Gram) 21.9
  • Circuit Type 32 Bit Programmable Digital
  • Motor Type 3 Pole Metal Brush Ferrite
  • Gear Material Metal
  • Bearing Type Top Ball Bearing
  • Output Shaft (type / Ømm) Standard 24
  • Case Material Plastic
  • Dust / Water Resistance N/A
  • Connector Gauge (AWG)/ Strand Count 28/ 20
More Info
Head to Hitec for more info...
Discussion Sig 4 Star 54 Hitech Servo Question jobinseattle Electric Plane Talk 3 Oct 10, 2015 04:05 AM
Discussion hitech micro servos. megaglow_Z Mini Helis 17 Apr 12, 2006 09:12 PM
GWS servos vs Hitech servos??? CactusJackSlade Slope 13 Jan 27, 2005 06:28 PM
Question Hitech servos vs GWS servos??? CactusJackSlade Thermal 5 Nov 06, 2002 04:59 PM
Servo cans for Hitech servos GliderGuider Electric Sailplanes 5 Jan 04, 2002 01:22 PM
