Jul 21, 2019, 01:21 PM
Originally Posted by T3X
@Olgoz....
Picture 1????
What did you do? Mowing the grass
Yeeaa sometimes have to stay low
Well it arrived, but I'm totally puzzled about the controller.
This one isn't the one on the pdf at the start of this thread, any one explain a bit.
Edit.
Found it, it's a skystars G730 F4 AIO
Edit.
Bummer they send me 3cw and 1ccw motors... Now... Waiting ��
You have the same FC as my STX225. I followed this from page 13 in this thread from kramersteen and I'm still mowing grass
Originally Posted by kramersteen
CAmera is - VIN(yellow)/5v(red)/gnd (black) (video in)
VTX - VOUT(yellow)/5v/gnd (video out ) Note If your vtx has smart audio you can send that wire to the TX3 pad and then turn it on in betaflight to gain smartaudio control.
RX - sbus(yellow)/5v/gnd
All modern flight controllers are like this.
What are you waiting for with cw and ccw motors? I would just fly! All mine are the wrong way round because I've reversed props and I don't seem to have to tighten them even though they are now effectively all self-loosening. I don't fly hard. For you if you build it right you'll only have to be concerned about one prop nut. Enjoy your quad it's awesome. Remember to bridge the pads above the camera and vtx pads on the fc to get vbat, otherwise there will be no power to them.
Jul 21, 2019, 03:23 PM
T3X
T3X
These pads [photo]? All three together?
Jul 22, 2019, 02:04 AM
NOT all 3 together! Yes those are the pads. Bridge as per the red lines I've put on your photo to get vbat to your vtx and camera.
Jul 22, 2019, 02:57 AM
T3X
T3X
Thank you, going to fix this today and put it on betaflight for the first time.
Everything works. Try some first hover and works, think to tune it some more because when pushing it forward it keeps going forward.
Just another problem with my lipo, see picture.
Is this beyond repair?
Jul 22, 2019, 01:55 PM
Glad it works
Your battery is repairable - same thing happened to me.
Make sure all the balance connector wires are isolated from each other so you don't short circuit the battery or over-discharge it.
You can buy another separate battery balance connector and carefully solder the wires together or re-pin into the new connector. The order of the wires is important. Or, and what I did, was I stored my broken balance connector battery with the wires well insulated. And when I ruined another battery, I cannibalized it's balance connector and used it to repair my battery.
Remember that Li-Po batteries can be disastrous if handled wrongly so take super care. Some people may just advise you to dispose of it!
Enjoy
Jul 22, 2019, 03:12 PM
T3X
T3X
Thx.
Just start from bottom to top. Top is the +. Doesn't seam to hard.
Jul 22, 2019, 03:17 PM
Fan of just about anything RC
SoloProFan's Avatar
If the battery has no other damage than the connector, it can be replaced, just make sure no wires touch, and as mentioned before, the correct order in the balance plug.
Latest blog entry: For the love of the hobby!
Jul 23, 2019, 11:34 AM
STX225 cinematic edit
grey2 (0 min 52 sec)
While you were talking about batteries..
Perhaps an opportunity to rebuild and dip paint the frame.
Check out this STX225 loom & STX225 frame with primer coat
Jul 29, 2019, 08:00 AM
T3X
T3X
Looking good.
As you know about my broken balance plug, I created a temporary solution photo 1, I also getting errors try loading on all my lipos, error cell connection, I opened the charger and found the problem. Soldered two wires and no problem now.
Time to get in the air... I have been practicing on a simulator the last 7 days.
Aug 07, 2019, 08:45 AM
STX225 w bi-blade low pitch props
Finally got my bi-blade props! Going to try them out just now..
They are Kingkong 5040. Slightly lower pitch than the STX225 5042 props.
Still waiting for JJRC JJPRO 5030 bi-blade props - even lower pitch.
I suspect efficiency AND performance will be better!
Otherwise why would the drone tech giants DJI not use tri-blades? From the research it looks to me like bi-blade is just BETTER.
I will update this post with informal "results."
I am also trying to LASER CUT some thin cork sheeting to use as motor mount dampeners - if anyone has a blueprint of the STX225 2204 motor bottom plate I would be most appreciative!
Oh, my hydro-dipping endeavour was an epic failure by the way - I think because my current atmospheric conditions being so dry, is not favourable to successful hydro-dipping. Took me about an hour to gently scratch all the messy paint off my frame..
Cheers for now.
UPDATE : With bi-blades definitely about 10% longer flight times. Not a lot but just noticeable. However, with bi-blades it is a bit wobbly at times. The odd yaw-jitter here and there. Perhaps such a light quad as this is more stable with grippy tri-blades..? Top-end speed is less with lower pitch bi-blades. The quad is a lot more portable and easier to pack in a smaller space with bi-blades. Also, with bi-blades, the sound of the quad in flight has a lower pitch.
Aug 08, 2019, 09:47 AM
Time For Me To Fly!
fastmax's Avatar
Bi blade props are more efficient, and in certain situations will generate a higher top speed, but they are less "grippy" in the corners, and they don't generate as much thrust as tri blade props.
Tri blades bite harder, so you can corner, and change directions more quickly, and the quad accelerates faster when coming out of those corners, and directional changes. DJI use bi blades because they give better flight times. Acceleration, speed, and cornering are not something they even consider.
Keep us posted on your results. I have no doubt that you will definitely see improved flight times, and probably a slight increase in top speed.
Aug 14, 2019, 03:12 PM
T3X
T3X
Hi to you all.
Just have been flying today, 30 seconds, crash and a wire from receiver has come of. So now I did some changes, put the akk endless vtx on, easy to record video with everything on the SD card including OSD. Nice but the quality is a bit crap. But have the firefly cam also, gives a clean view but with 160 degree it looks a tiny bit odd.
But I think I need a bigger drone.... Just kidding.
Discussion Airbot Wraith 32 MINI V2 - 32bit 35A BLHeli 32 ESC josephr Multirotor Drone Power Systems 24 Apr 13, 2019 03:13 PM
New Product FrSky VANTAC BQ210 BNF 210mm FPV Racing Drone 5.8G 48CH F4 35A Blheli-32 Dshot1200 25 scousethief Banggood.com 0 Aug 20, 2018 06:24 AM
Discussion RED HARE 215mm RC FPV Racing Drone with OMVT F4 OSD BLHeli_S 35A 4in1 ESC 5.8G 48CH V scousethief Banggood.com 0 Apr 26, 2018 08:27 AM
New Product HGLRC F4 ZEUS( F4 FC+13A ESC All in one) Pre-order Now!!! HGLRC Company Multirotor Drone Electronics 21 Apr 13, 2018 10:12 AM
Discussion Holybro Kakute F4 V2 FC - Atlalt HV 25-600mW 40CH VTX - Tekko32 35A 4 In 1 BLHeli 32 BobFromMars Banggood.com 5 Apr 09, 2018 07:37 AM
