This thread is privately moderated by mmalmsten, who may elect to delete unwanted replies.
Sep 11, 2018, 07:07 PM
mmalmsten's Avatar
Hobbyzone SuperCub (At least it used to be)
My first plane was a HobbyZone SuperCub that I got for Xmas several years ago. I have crashed and bashed it several times over the years so outside of the basic foam pieces it does not much in common with the original plane. It basically has become a test bed for developing/testing out building techniques, etc.
I have modified the wing so that it bolts on rather use rubber bands, replaced all the electronics and added ailerons, flaps and built floats for it.
I thought I would create this thread to document some of the changes I have made in the past and moving forward.
Sep 11, 2018, 07:32 PM
mmalmsten's Avatar
Floats for the SuperCub
I found some plans on the web for floats and designed a pair to fit the cub using an article from Chuck Cunningham to size and mount them properly. I built the floats out of pink foam and covered them with fiberglass. They are very light weight and work great. Some build pictures of the floats below.
Sep 11, 2018, 09:08 PM
mmalmsten's Avatar
The Latest Bash
My last crash was pretty hard spin into the ground that cracked the fuse just in front of the rudder/elevator. After Gorilla Gluing it back together the fuse was still spongy so I had to make a decision finally scrap the plane or go all in on a repair.
I decided to go all in on the repair as it provided me an opportunity to try covering foam with brown masking paper. Besides the fuse issue the wing was getting spongy from to many flights with the original loose wing struts. I ended up covering the whole plane using TiteBond II and am pretty happy with the results. I did not save the numbers but the weight gain was not as bad as I thought it would be. The resulting covering definitely stiffened everything back up and it also provided a good surface for painting.
Besides the covering I redid the wind struts. The bolt onto the fuse and attached solidly to the wings. I used fairly thing piano wire covered with bass wood. These are solid and look way better.
For the pain scheme I decide to paint it as an Alaska State Trooper plane. Since I plan to fly this off of floats more than anything I thought it was a cool combination.
Some pictures below.
Sep 11, 2018, 09:13 PM
mmalmsten's Avatar
More Pictures of the Latest Incarnation
Some more pictures.
Sep 11, 2018, 09:26 PM
mmalmsten's Avatar
Rudder for Floats
I was having some steering issues on my water take-offs so added a rudder for the floats. It is a pull-pull system connected to the rudder servo. I used 8 lb spider wire fishing line for the cable. The rudder flips up as you gain speed in the water.
IMG 3116 (0 min 27 sec)
Nov 24, 2018, 03:19 PM
mmalmsten's Avatar
On the Water
First time out on the water after some rework on the plane. Also fist time on the water with the water rudder working.
Flight was very shaky as there was a bit of wind and I was having some trouble with control. I found out later I was flying withe Tx throws set to low ....
The landing is anything but textbook (comment by my son in video) however I was happy to just to get it down.
Taxi/Take-off
VID 20181123 102036 (1 min 50 sec)
Landing/Taxi
VID 20181123 102352 (1 min 12 sec)
Nov 25, 2018, 09:17 AM
Nice landing!��
Discussion At least he's honest he wants to be a dictator of the USA jazzmanb Life, The Universe, and Politics 5 Jun 15, 2018 05:12 PM
Discussion Horrible fire in mall kills at least 64 human beings. rcposter Life, The Universe, and Politics 5 Mar 26, 2018 11:36 AM
Alert There has to be at least 2 VTX antennas. *READ NOW IMPORTANT* AntDX316 FPV Talk 36 May 12, 2016 01:56 PM
Question Is there software to test at least basic airplane design using a good physics engine? RobertTHaas Hand Launch 6 Oct 19, 2015 12:45 PM
Discussion Being involved with your government still works, at least at the state level... Dave Campbell Life, The Universe, and Politics 90 Apr 19, 2014 12:55 PM
