Sep 11, 2018, 05:13 PM
Flyzone beaver rh float takes on water
Flyzone Beaver rh float takes in water while taxiing, When i pull the plane and hold it vertically 40 plus drops drain from the float..left float is fine. Mystery leak somewhere..anyone else had this problem?
Sep 12, 2018, 12:12 PM
I can fix that!
doug.wagner's Avatar
Hi Willy!
I've flown the Beaver like a Maineiac (pun intended), since it came out, without any leaks.
It has not had an easy life
I would hold the float underwater, to see where the bubbles are coming from.
A little silicone smeared in, and over the hole, should fix it.
Sep 12, 2018, 12:23 PM
Thanks doug..leak is at the split where the float "steps". 3 psi showed the bubbles.
Sep 14, 2018, 06:20 PM
I can fix that!
Good...hopefully it will be an easy fix.
Sep 15, 2018, 05:49 AM
So far so good.
Discussion Beaver on Floats - Which has better flying characteristics - Flyzone or Dynam lvflyer Waterplanes 3 Nov 18, 2016 01:00 PM
Question Flyzone Beaver on Floats madwinger Waterplanes 11 May 23, 2016 11:06 PM
Question Flyzone DHC-2 Beaver. Horrible steering on water zcampbell0127 Electric Plane Talk 4 Jul 16, 2014 09:32 AM
Beaver on floats, won't turn on water! JustFly Waterplanes 6 May 19, 2005 12:27 PM
