Oct 05, 2018, 01:05 PM
radfordc's Avatar
Here's a bunch of takeoffs and landings while getting the elevator/flap mixing dialed in. I ended up using 12% up elevator mixing with my Horus radio. Lands like a butterfly with sore feet.
Phoenix Model Stuka Takeoff Landings (6 min 21 sec)
Latest blog entry: Assembling a Spandau kit.
Oct 05, 2018, 01:08 PM
radfordc's Avatar
One concern with a Stuka is the highly tapered wing causing tip stall issues. This plane absolutely doesn't have that problem. Lots of washout built into the wing.
Oct 05, 2018, 03:11 PM
Do the wings attach the same way the smaller Phoenix Stuka attaches? That is the only thing i don't like about mine.
Oct 05, 2018, 04:33 PM
radfordc's Avatar
Haven't seen the small one. These wings slide onto aluminum tubes...four aluminum brackets slide into the fuselage and are locked with small bolts. If the bolts come loose the wings will likely come off in flight. I'm trying to think of a better way.
Oct 05, 2018, 04:35 PM
radfordc's Avatar
Well, the little Nazi came today. With a bit of work he might do. Not all pilots were giants back in the day.
Oct 08, 2018, 09:09 AM
radfordc's Avatar
That will do.
Oct 08, 2018, 10:32 AM
Originally Posted by radfordc
That will do.
Came out nice.
Oct 10, 2018, 01:13 PM
radfordc's Avatar
Final all up weight is 23 lbs 14oz.
Oct 11, 2018, 07:51 AM
So 2 oz shy of 2 lbs worth or armament. Wonder how that affects the CG and how it flies with the additional drag. It appears that your DLE55 gets adequate cooling? Thank you for the gorgeous pictures.
Oct 11, 2018, 10:02 AM
radfordc's Avatar
Yes, it stays cool so far...but I only flew it on a cool day. I did install a baffle around the engine cylinder so that all the incoming air is directed through the fins.
Oct 11, 2018, 06:32 PM
Same way as the smaller Stuka except there are only 2 bolts. If i had more room inside i would use some nylon wing bolts as well from the inside of the fuse to the wing.
Oct 13, 2018, 03:16 PM
radfordc's Avatar
Check you landing gear strut screws!
When I assembled the plane I looked at how the LG struts were installed and checked the tightness of all 6-8 set screws on each gear. I should have removed the screws and reinstalled with Locktite. Today, one of the struts fell out while in flight. I landed OK with only minor damage to the left landing gear fairing.
Oct 14, 2018, 12:31 PM
radfordc's Avatar
Not too bad damage for landing a 24 lb model on nothing but a plastic fairing! I did say that this plane lands really easy and smooth.
Oct 14, 2018, 12:34 PM
radfordc's Avatar
Battle damage repaired and ready for another mission over the Eastern Front!
BTW, Tower Hobby kind of pissed me off this week. They sent me an email asking for a review of the Stuka. I put together a detailed review with pictures of my plane and a video of me flying it. Tower rejected the review some reason that I can't imagine. So much for trying to promote their product.
Oct 14, 2018, 12:37 PM
radfordc's Avatar
Here you can see that the set screws had been tight enough to bite into the mounting strut. I replace the gear with plenty of locktite so hopefully this won't happen again. The screws in the other gear were also loose.
Discussion Ju-87 Stuka 1/4 scale fokkerc.com fokke Fuel Warbirds 18 Nov 12, 2018 11:08 PM
Discussion Phoenix 60cc 94.4" JU-87 Stuka Aros.MotionRC Scale ARF/RTF 3 Jul 31, 2018 10:38 AM
Question Phoenix Model Stuka Ju 87 GP/EP ARF 75.2" jobinseattle Electric Plane Talk 1 Nov 02, 2016 11:46 AM
Contest FunBuild 4 Aero-werks JU-87 Stuka glewis Scale Kit/Scratch Built 329 Sep 06, 2011 06:45 PM
Scale Model JU-87 STUKA convert from paper model yctseng Scale Kit/Scratch Built 37 Nov 30, 2007 03:17 PM
