Video
Headplay SE V2 7" FPV Goggles, 40Ch, 5.8GHz, DVR, HDMI, Speaker, Latency 15ms
Headplay SE V2 7" FPV Goggles, 40Ch, 5.8GHz, external DVR, HDMI, Speaker, Latency 15ms
Banggood
Description: Brand Name: Headplay Item Name: Headplay SE V2 Frequency: 5.8GHz Channel: 40CH Voltage Input: 2S-4S LiPo XT60 (not included) Latency: 15ms Antenna Connector: SMA Features: Low latency LCD - best racing performance 15 ms low latency video - even during active DVR recording Never blue or black screen during FPV HDMI-in for HD FPV Smart design prevents cable from snapping if pulled by accident Plug-and-play with HD FPV links Patented ergonomic design Light weight Classic Headplay design spreads weight evenly on forehead and cheeks Superior comfort, materials, fit and finish Three point adjustable straps with silicone ant-slip belt Five new colors: Monster Green, Platinum Silver, Battleship Gray, Headplay Blue, Matte Black Rubber texture resists scratches and keeps new appearance longer Headplay F220 mm lens For a cinematic immersive feeling HPRO lens HPRO lens is included and offers a much more narrow FOV for fast FPV racing action AV-in for connecting to FPV base station Connect the Headplay to your existing FPV receiver AV-in and AV-out are connected to the DVR, but it’s possible to disconnect the DVR and DIY connect AV-in (i.e. 1.3 GHz video Rx) to the AV-input; and if you keep the AV-out connected to the DVR, you can record the external AV input with the DVR XT60 battery input for all day run time Simple and smart battery holder for standard 2S-4S racing packs with XT60 connector OSD voltage display with low battery warning Voltage display can be moved to any corner of the screen or turned off New 5.8 GHz receiver with autoscan channel finder Design by Hawkeye Improved sensitivity over previous Headplay Rx 40 channels with Raceband channels Band and channel indicator LED Band and Channel selection 5865 MHZ 5845 MHZ 5825 MHZ 5805 MHZ 5785 MHZ 5765 MHZ 5745 MHZ 5725 MHZ 5733 MHZ 5752 MHZ 5771 MHZ 5790 MHZ 5809 MHZ 5828 MHZ 5847 MHZ 5866 MHZ 5705 MHZ 5685 MHZ 5665 MHZ 5645 MHZ 5885 MHZ 5905 MHZ 5925 MHZ 5945 MHZ 5740 MHZ 5760 MHZ 5780 MHZ 5800 MHZ 5820 MHZ 5840 MHZ 5860 MHZ 5880 MHZ 5658 MHZ 5695 MHZ 5732 MHZ 5769 MHZ 5806 MHZ 5843 MHZ 5880 MHZ 5917 MHZ External DVR record video: VGA: 640x480 D1: 720x480 HD: 1280x720 Package Included: 1 x Headplay SE V2 FPV Goggles 1 x Clover Mushroom antenna (RHCP) with SMA Male connector 1 x DVR with additional cable 1 x HPRO lens 1 x Main cable for battery (XT60 connector) and DVR connecting 1 x Face foam (made of foam rubber): thick (15mm) and thin (7mm) 1 x Nylon bag |
Thread Tools | |
Similar Threads | |||||
New Product | FXT Marvel II 5 Inch 800*480 40CH 5.8G Diversity FPV Goggle HDMI Build-in DVR | BG Flandre | FPV Equipment | 61 | May 25, 2019 10:16 PM |
Discussion | Skysight RC708 5.8G 7" LCD 40CH Diversity with HDMI DVR | downloader9 | FPV Equipment | 9 | Jul 07, 2018 09:05 PM |
New Product | [165$ sale] Headplay SE V2 5.8G 40CH FPV Goggles Video Glasses Headset With DVR | nitbeat | FPV Equipment | 15 | Oct 07, 2017 03:22 AM |
New Product | Eachine Goggles One, 5" 5.8GHz 40CH 1920x1080 HDMI FPV Goggles | FyreSG | FPV Equipment | 580 | Oct 02, 2017 07:20 AM |
Discussion | FXT Version II 5 Inch 800*480 40CH 5.8G Diversity FPV Goggle HDMI Biuld-in DVR | scousethief | Banggood.com | 0 | Jul 15, 2017 10:57 AM |
