This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
Sep 06, 2018, 10:21 PM
Gary Chen's Avatar
30X zoom camera for fix wing and VTOL, with object tracking
Sky Eye-U30 1080P 30X Optical Zoom Camera With Tracking And Geotagging (2 min 46 sec)
Sky Eye-U30 gyro-stabilized camera payload can be mounted on any fixed-wing or VTOL Unmanned Aerial Vehicle. It combines cutting-edge technologies in lightweight, affordable, gyro-stabilized gimbal system. Which makes it a perfect choice for applications like inspection, surveillance, search, and rescue.
High quality video sensor
Sky Eye-U30 is using SONY FCB-EV7520 camera block, which provides 1080P 60FPS full HD video streaming and up to 360X zoom capability. It also features anti-fog, video enhancement, and some other advanced features.
Auto object tracking
With onboard object tracking module, Sky Eye-U30 is able to track static or moving target easily, keeping it in the center of the frame.
Easy for integration
Sky Eye-U30 can not only be controlled via PWM signal, but also serial command. Also gimbal status(like Yaw/Pitch angle, zoom position etc) can be obtained by sending serial command to the gimbal via its serial port, which is really useful for precise gimbal control and system integration.
Clean and simple wiring
Sky Eye-U30 comes with one wiring hub for RC receiver and video output port, which makes wiring pretty easy and clean. Also, the gimbal offers 2 smart speed modes: FAST speed and LOW speed. Fast speed mode is used for small zooming range, which makes the gimbal control sensitive and quick. LOW-speed mode is used for large zoom range, will enable you to target the object more accurately.
Compact and lightweight
Sky Eye-U30 weighs as little as 690g to help you meet your payload weight allowance.
Discussion 30X EO/IR drone zoom camera with object tracking and geotagging Gary Chen Multirotor Drone Talk 1 Oct 22, 2017 09:43 PM
New Product 1080P 30X Optical Zoom Camera With Auto Object Tracking Module Gary Chen Multirotor Drone Talk 3 Jun 07, 2017 11:10 PM
