This thread is privately moderated by l shems, who may elect to delete unwanted replies.
Sep 06, 2018, 12:11 PM
Have Fun and Just Fly!
l shems's Avatar
Mini-HowTo
Easy way to save and load a table in OpenTX lua scripts
With read and write access in LUA on opentx, it is tempting to use a settings file to persist certain user choices for some scripts. However, though writing a settings table to a file is easy, retrieving it by reading the file content string per string is tricky. Formatting, nested structures, etc.
The solution to this is to write the table to a settings file in a format that is lua interpretable, and will return a table on using the lua loadfile() command.
In this way, you use the lua interpreter to parse the structure from the save table.
The following script, to be saved under the name "saveTable.lua", can be used to dump a table to a file, that is then retrievable using loadfile().
Code:
local table,fileName=...
local indent = ""
local function outputTable (tbl)
  if not (type(tbl)=="table") then
    return tbl
  end
  indent=indent .. "   "
  local res= "\n" .. indent .. "{\n"
  for k, v in pairs(tbl) do
    if type(k) == "number" then
      k="[" .. k .. "]"
    end
    if type(v) == "table" then
      res=res .. indent .. k .. " = " .. outputTable(v) .. ",\n"
    elseif type(v) == "function" then
    elseif type(v) == "string" then
      res=res .. indent .. k .. " = '" .. v .. "',\n"
    elseif type(v) == "boolean" then
      if v then res=res .. indent .. k .. " = true,\n"
      else res=res .. indent .. k .. " = false,\n"
      end
    else
      res=res .. indent .. k .. " = " .. v .. ",\n"
    end
  end
  res = res ..   indent .. "}"
  indent=string.sub(indent,4)
  return res
end
if io and (type(table) == "table") then
  local f = io.open(fileName, "w")
  io.write(f,"return " .. outputTable(table))
  io.close(f)
  f=nil
end
The table is saved by calling
Code:
loadfile("saveTable.lua")(tableToSave,"SavedTable")
the table can be loaded into a variable by:
Code:
table=loadfile("SavedTable")()
The following demofile must be run from the sdcard browser. it shows a counter that is increased by pressing enter. After stopping and restarting the script, it will continue on the last value:
Code:
local script = {}
local data = {test=1}
script.init = function()
  if loadfile("savedData") then
    data = loadfile("savedData")()
  end
end
script.background = function() end
script.run = function (event)
  lcd.clear()
  lcd.drawText(1,1,data.test)
  if event == EVT_ENTER_BREAK then
    data.test = data.test + 1
    loadfile("saveTable.lua")(data,"savedData")
  end
  return 0
end
return script
Good luck!
P.S. the attached files need to be placed in the sdcard root folder.
Dec 26, 2018, 11:35 AM
Because my data table was so large, it takes too much memory to store two tables, and two much CPU time to save the whole thing in 30 mS. Therefore, I save each key of my settings as a separate file. Additionally, they are specific to each mode.
If a setting isn't found on the SD card, the default settings are used and a new SD card file is created.
Here's the code that accomplishes it.
local sName = "DATA_" .. model.getInfo().name .. "_"
for k,v in pairs(mySettings) do
local settingFileName = sName .. k
if loadfile("/myFolder/" .. settingFileName) then --load setting from sd, overwrite default
mySettings[k] = loadfile("/myFolder/" .. settingFileName)
print(k .. "overwritten")
else --create SD setting file from default
loadfile("/myFolder/saveTable.lua")(mySettings[k],"/myFolder/" .. settingFileName)
end
end
This method is also nice because an adjustment in the menu of one setting does not require writing the entire table to the SD card.
The one downside of this method is all the files end up in the same folder. If I could create folders in the SD card for each model using Lua, that would be great!
Dec 26, 2018, 03:38 PM
l shems's Avatar
Just wait for the new OpenTX version. Seems to support all that.
If not, well, ???
Dec 28, 2018, 10:12 AM
Originally Posted by l shems
just wait for the new opentx version. Seems to support all that.
If not, well, ???
new opentx version = 2.3?
Dec 28, 2018, 12:55 PM
l shems's Avatar
Yep. I think I saw some pull requests passing. Max Paperno was busy with it.
Question OpenTx Horus LUA Scripts sten1860 Multirotor Drone Electronics 1 Nov 05, 2017 08:13 AM
Question OpenTx Horus LUA Scripts sten1860 Radios 0 Oct 31, 2017 04:11 AM
New Product Taranis Q X7 OpenTX Battery Capacity Remaining Lua Script RcRav Radios 0 Mar 31, 2017 03:17 PM
Discussion OpenTx Lua Script Lap Timer RcRav Radios 0 Jan 10, 2017 02:08 PM
Discussion L/D and Sink rate LUA script for OpenTx FabFlight Sailplane Talk 2 Mar 23, 2016 07:28 PM
