Sep 06, 2018, 03:47 AM
GeDiFly's Avatar
Video
Seagull Depron 1360mm 279g
My Seagull CLARA - 05-09-2018
1360mm - 279g - Brushless 2208/14 - 2S 1000mAh - Prop 7 x 4 -
Clara an her friends in Cologne >>>
✈ Möwe Seagull Clara in Köln Cologne am Rhein (6 min 22 sec)
Construction & plan Hilmar Lange www.lange-flugzeit.de
Plan available VTH-Verlag
Georg D
Sep 06, 2018, 04:45 AM
Danish? Don't U eat that??
DKChris's Avatar
Positively love it! Also that it's made with a simple KfM wing.
How did you get the "gull wing" shape in the wing? Is there a shaped spar or something?
Sep 06, 2018, 06:23 AM
GeDiFly's Avatar
Seagull wings
construction of seagullwing
images - attached files >>>
Georg D
Sep 06, 2018, 06:43 AM
DKChris's Avatar
Ok, thanks very much
Pretty straight forward I see. I assume the wing halves are assembled with a lightly bent piece of piano wire as a joiner(?)
Since you also sand down the step(and TE) to a smooth transistion, its only "sort of" a KfM profile; May cost a little lift, but probably doesn't exactly hurt with regard to drag. Seems to be the right approach. Certainly does fly very "scale" .
I feel quite compelled to do a herring gull (Silbermöwe), as they are the most common kind up here. Plus it's an easy paintjob
I'm a bit surprised that it looks to be all 6mm depron? Not a bad thing though. Climapor is easy to get from Bauhaus.
Sep 06, 2018, 05:48 PM
skumgummi dave
Lovely!
Nov 07, 2019, 02:46 AM
GeDiFly's Avatar
Seagull "Laura" 50g
Die kleine Schwester von Clara, nach einem Bauplan (50% verkleinert) von Hilmar Lange
"Laura" Modelldaten
690 mm Spannweite
280 mm Länge
50 g Fluggewicht
5 g BL-Motor
5 x 3 Prop
2S 180 mAh Akku
Spektrum Micro Empfänger, Regler, Servos
Auf den Erstflug in den nächsten Tagen bin ich gespannt.
Georg D
✈ Fliegender Koffer
Nov 07, 2019, 04:26 AM
DKChris's Avatar
Ich mit! Sieht viel versprechend aus
Wird der Erstflug 'ne Hallenflug sein? "Laura" gehört ja technisch gesehen mehr oder weniger in die Ultralight Klasse, und obwohl Ich mich nicht gerade besonders mit typischem Wetter in der Kölner Gegend auskenne, würde ich unmittelbar annehmen dass Winter auch bei euch stark in Anmarch ist? Könnte vielleicht etwas zu windig für die Kleine werden?
Nov 11, 2019, 07:46 AM
GeDiFly's Avatar
LAURA Seagull 50g
...sie fliegt - Erstflug - Maidenflight - Indoor - Outdoor - seht selbst
✈ RC Seagull Möwe Laura - 50g - DIY (5 min 10 sec)
Georg D
Nov 11, 2019, 09:24 AM
DKChris's Avatar
Einfach schön
Mir staunt insbesonderes wie wendig und troztdem stabil die beiden Möven-damen sind, obwohl die abstand vom CG bis zur rudeflächen so gering ist - liegt wahrscheinlich am flügelform?
Nov 11, 2019, 07:41 PM
very nice, Link for Plan Is not valid
Nov 11, 2019, 11:52 PM
GeDiFly's Avatar
Bauplan Seagull Möwe Lara von Hilmar Lange
...Infos zum Bauplan
Hilmar Lange: http://www.lange-flugzeit.de/?post_t...lication&p=456
VTH-Shop: https://shop.vth.de/bauplan-lara-3201377
Georg D
Video 1.2m depron Tigermoth anewton Electric Warbirds 5 Dec 10, 2015 05:19 PM
Discussion Which plane - Seagull Nemesis nxt .46 or Seagull challenger ARTF Scottish_steve75 Fuel Plane Talk 0 Nov 04, 2015 07:56 AM
Help! Anything made from Depron 3/6mm with existing Motor man1ac Foamies (Scratchbuilt) 7 Sep 18, 2015 05:06 AM
Discussion Flite Test plans and 6mm Depron aritchie71 Foamies (Scratchbuilt) 3 Sep 15, 2015 02:33 PM
