Durafly have based this model on one of the development planes that had a striking orange and silver color scheme which is combined with the highly detailed, molded EPO foam, strong carbon reinforcement and features a color matched hard plastic belly skid. The J8M Shusui still has the blistering performance of the earlier ME-163 and the wide track “dolly” for easier ground handling and take off.
Durafly J8M Shusui 950mm - HobbyKing Product Video (1 min 53 sec) |
As a PnF model, the J8M Shusui comes with all electronics pre-installed and requires you to hook up to your 6ch receiver. This is an easy build with only a few parts to be put together. A big hatch gives easy access to the battery bay and electronics.
This plane is designed with the more experienced pilots in mind. The J8M Shusui has incredible flight performance and is stable throughout the complete speed range. Full power climb outs, virtually unlimited vertical, huge loops, blistering rolls and very fast passes are easily had at full throttle. At slower speeds, the J8M Shusui is just as stable with no hint of a stall.
Using the recommended 2200mAh 30-65C 3S lipo and supplied 6x4 prop, you can expect flight times well beyond 6 minutes and with excellent performance throughout. But if you want a bit more punch then a 1300~2200mAh 4S 30C+ lipo can be used with the standard J8M Shusui setup.
Thread Tools |
Jason Cole has already done a RcGroups "News" thread on this plane!!
Here........https://www.rcgroups.com/forums/show...shi-J8M-Shusui |
Thread Tools | |
Similar Threads | |||||
News | Durafly Mitsubishi J8M Shusui | Jason Cole | Electric Warbirds | 85 | Apr 28, 2020 05:51 AM |
Scratch EPP Mitsubishi J8M1 Shusui | surfimp | Slope | 63 | Jul 19, 2004 07:25 PM |
