KR84 Tortuga Robodrone Pusher Jet
The New Tortuga from SAB Avio is an awesome looking and performing pusher Jet. This thing is made from fiberglass and is very rigid and strong so that it can reach high speeds easily.
Killer Looking Fiberglass Jet
The New Tortuga from SAB Avio is an awesome looking and performing pusher Jet. This thing is made from fiberglass and is very rigid and strong so that it can reach high speeds easily. It comes painted with a killer looking trim scheme that is highly visible, which is a good thing at high speeds. The control horns are pre-installed and it will only take around 2 hours to finish the assembly and install your electronics to get it ready to fly.
They recommend a 28mm to 36mm sized motor around 2200kv and a 6S battery. It will need a 100-120A ESC and a 5x5 prop. This is a beast of a prop jet with functional canards and it just looks amazing. The price is listed at $349 at AeroPanda with delivery slated for mid September.
Check out the KR84 Tortuga Robodrone Pusher Jet Here
Specifications:
  • Wing Span: 33" (84cm)
  • Wing Area: 2400 cm2
  • Maximum Length: 32" (81cm)
  • Weight RTF: 1.55 Kg (Maximum Total Weight: 1.7 Kg)
Sep 05, 2018, 02:21 PM
Wow that landing was hot.
Sep 05, 2018, 03:34 PM
cannondale1974's Avatar
Those are two of the best heli pilots in the world.
Wonder what the top speed on that thing is. Maybe someone can doppler it.
Sep 06, 2018, 01:28 PM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
Very appealing... like a refined Funjet.
Sep 06, 2018, 08:22 PM
Panhead5496's Avatar
I am a RC boat/truck/quad guy and have a trainer plane that is tricky to fly at times...I have no idea how anyone can fly something going that fast!! I would have a heart attack. It seems that it gets away from your sight so fast I don't see how you keep orientation?
Sep 06, 2018, 09:00 PM
When flying fast, I really am just directing a dot. Not really looking for aircraft orientation per say, just see what direction it is moving and make small adjustments.
Sep 06, 2018, 10:41 PM
Gotcha. I meant orientation as in which was was facing up haha! I guess at those speeds it's just a different kind of flying.
Sep 07, 2018, 12:13 AM
Just bump back on the stick and see which way it goes
Sep 08, 2018, 04:19 PM
I want one so badly,
Nowhere for ready something this fast...
What setup are people going use?
Thinking
HW 100 AMp
BK servos
and Xnova Motr
Sep 09, 2018, 12:28 AM
FPV it!
Sep 09, 2018, 07:56 AM
https://www.rcgroups.com/forums/show...O-KR84-Tortuga
Oct 01, 2018, 06:31 PM
I thought about using my Funjet as a plug to make a mold for a fiberglass version but decided it was too much work. It's good to see someone else had a similar idea, that's pretty awesome especially with the canards. I bet the Funjet would be a great flyer with canards. I'd like to see the twin prop version make a comeback!
Discussion SABAVIO KR84 Tortuga DepecheMode High Performance 279 Jul 03, 2019 10:35 PM
Discussion i have a pusher jet f16 fiberglass fuse sherlockshah Power Systems 3 Mar 30, 2019 02:22 PM
Discussion taft viper jet pusher prop arnauddecotter FPV Aircraft 294 Jul 13, 2017 06:04 AM
Help! plans for 80inch f22 pusher prop jet jetdeck Pusher Prop Jet Models 0 Dec 31, 2015 11:02 AM
Question GWS jets adapted to pusher prop? zen4013 Foamies (Kits) 5 Dec 30, 2015 09:09 PM
