HOBBYMATE D6 Duo Pro AC/DC Battery Charger w/ Wireless Cellphone Charging
The D6 from HOBBYMATE looks to be a killer charger with great standard features, but it has one breakout feature that I'm really excited about, wireless cellphone charging.
Awesome New Charger with Wireless Charging
OK, there are a bunch of battery chargers out there with plenty of choices and features to go around. I love battery chargers and I'm always looking for new ones with the latest technology and to see what they will come up with next. The D6 from HOBBYMATE looks to be a killer charger with great standard features, but it has one breakout feature that I'm really excited about, wireless cellphone charging.
That's right, the top of the charger is a wireless charging pad so if your phone supports that, you can place the phone on top of the charger and it will charge your phone. I also like that the charger runs on either AC or DC input power and has a nice color screen that shows all the info you need to know for both charging ports. You do need to be aware of the power limits for each input type, AC is limited to 200W while DC pumps it out at up to 650W. The price seems reasonable too at $149.90.
Check out the HOBBYMATE D6 Duo Pro AC/DC Battery Charger w/ Wireless Cellphone Charging Here
Features:
  • Auto detecting lipo cells.
  • Dual independent charging ports
  • Optimized operating software
  • Internal independent lithium battery balancer
  • Balancing individual cells during battery discharging
  • Adaptable to various types of lithium batteries
  • Fast charge and storage modes of lithium batteries
  • Data store/load
  • Terminal voltage control(TVC)
  • LiPo battery meter
  • Maximum safety Automatic charging current limit
  • Adjustable capacity and charging time limits
  • Temperature Threshold(temperature probe is not included)
  • Processing time limit
  • Internal Resistance Measurement
  • Activation and Restoration for Excessive Discharged Battery
  • External Discharge Function
  • Wireless Phone Charging
Specifications:
  • Input Voltage: AC100~240V / DC 6.5~30V
  • Charge Current: 0.1~15A ◊ 2
  • Charge Power: C 325W ◊ 2(650W)
  • AC 200W(Support power distribution)
  • Discharge Power Internal discharge: 15Wx2 (balance port 10W)
  • External discharge: 325W ◊ 2(650W)
  • Battery Type LiHv/LiPo/LiFe/Lilon/Lixx : 1~6S
  • NiZn/Nicd/NiMH : 1~16S
  • Smart Battery: 1~6S
  • Lead Acid(Pb): 2~24V
  • Enelop : 1~16S
  • Balance Current: 1600mA ◊ 2
  • Discharge Current: 0.1~3A ◊ 2
  • External Discharge Current: 1~15A ◊ 2
  • USB Output: 5V / 2.1A
  • Dimensions: 108 ◊105 ◊ 76mm
  • Net Weight: 555g
Hobbymate D6 Duo Pro AC/DC Smart Charger (19 min 16 sec)
Sep 05, 2018, 12:47 AM
The original Flying Pigs Sqd.
Up&Away's Avatar
SKYRC D100 V2 - at Aliexpress, free shipping, just over $100
Same specs, less the wireless mobile phone charger...
Sep 06, 2018, 02:52 PM
I really like that feature that allows you to dump voltage from unused flight batteries back into a "source" battery. This feature would help me when I return from a day of flying and have some batteries to discharge. I can use them to charge my field charging battery! For that reason alone, I want this charger. Problem is...I already have two chargers, lol.
Sep 06, 2018, 07:55 PM
MK
MK
Other high end chargers do the same of dumping the charge back to the source battery.
Sep 06, 2018, 08:44 PM
RCG Admin
Jason Cole's Avatar
Only two?!? I have like 10 or more!! Yes I can't help myself sometimes. I probably have too many chargers....
Sep 06, 2018, 08:51 PM
EDF all the way!
bruff's Avatar
I have one love it.
bob
Sep 07, 2018, 07:22 AM
I didn't think this was high end...
Jason, you my friend are a bad influence!
Sep 09, 2018, 11:20 AM
MSgt, USAF Ret.
Jim Frahm's Avatar
Iím in the same boat as you,,,, I have more chargers than batteries.
Feb 01, 2020, 06:54 PM
User Registered
RustyUs's Avatar
Regenerative discharging feature is not on this charger. At least that is my understanding on the "External Discharge Function".
Feb 02, 2020, 10:29 AM
All Day I Dream About RC
While the Hobbymate D6 Pro does not have a devoted regenerative discharge function like the Hobbymate Speed H6, there is a work-around that accomplishes nearly the same result. You can use the battery you want to discharge as the source power (with AC power unplugged of course) for the charger and connect the battery that you want to transfer the energy to as the battery that is being charged. The charging power will be the discharge rate. Before starting, you need to set the desired discharge termination voltage in the system parameters menu (min input voltage). The min input voltage is only available on 0.5v increments but it will get you close. Be sure to disconnect the source battery shortly after finishing discharging as it will continue to be discharged slightly as it powers the idle charger. Hope this helps.
Feb 10, 2020, 06:58 PM
User Registered
RustyUs's Avatar
Thanks for that info adidarc. I'm gonna have to give that a try.
Video HOBBYMATE D6 Duo Pro: Dual channel LIPO charger recwap Batteries and Chargers 0 Jul 22, 2018 07:57 AM
Download HOBBYMATE DUO CHARGER AC/DC Lipo Balance Charger HOBBYMATE Vendor Talk 0 Apr 12, 2017 01:32 AM
Mini-Review Hobbymate Duo AC/DC 120W x 2 Charger adidarc Batteries and Chargers 3 Dec 16, 2016 10:55 PM
