Sep 03, 2018, 03:36 PM
sawacs's Avatar
MKS HBL 990+Trex 760x Tail Alignment Issue
Do you guys happen to know if the MKS HBL 990 servo control arm spur gear is in a slightly different location than the Align tail servo spur gears?
Here is the reason I ask.
I cannot get the Trex 760x tail control balls links threaded onto the tail pushrod far enough to be considered secure without screwing up the 90 degree servo arm vs blade angle geometry. What I mean by this is if I adjust the ball links properly, where the tail servo control arm is at a 90 degree angle and the tail blade tips are in alignment, the ball links are about to fall off of the threaded rods on each end of the tail control pushrod. In order to get the tail blade tips to align properly, I have to add sub-trim to the MKS servo which creates a 10 or more degree offset in the servo arm from the normal 90 degree orientation.
I have checked everything I can possibly think of.....correct ball links are installed, the pushrod is indeed for the 760x, the tail servo is mounted correctly etc..
The only two explanations I can think of is either the 760x tail control pushrod is slightly short from the factory or the MKS HBL 990 servo's control horn spur gear is slightly more toward the center of the servo than the Align servo.
Any advice would be greatly appreciated.
Sep 04, 2018, 03:25 PM
sawacs's Avatar
Update:
Problem figured out.... The tail control rod for the Trex 760x is 5/16" shorter than it is supposed to be and explains why I am unable to get the servo horn and blade tips centered..
News Align T-REX 760X F3C Dominator / 760X 3D TOP ndfly700 Electric Heli Talk 4 May 03, 2017 01:45 AM
News Align Trex 700/800 Autorotation Tail Drive Gear & Torque Tube Front Drive Gear ndfly700 Electric Heli Talk 3 Nov 14, 2016 04:51 PM
Discussion MKS X8 Servo / HBL 950 Servo groom_k 3D Fuel Heli Flying 1 Apr 09, 2013 11:52 AM
Discussion MKS X8 Servo / HBL 950 Servo groom_k 3D Electric Heli Flying 1 Apr 02, 2013 06:28 AM
Discussion T-Rex 700e With MKS HBL665 + HBL 669 Jamiem 3D Electric Heli Flying 4 Jun 20, 2012 02:47 PM
