Dec 22, 2004, 03:00 PM
E-Flite Ultimate EP Build/Modifications
I called this thread the E-Flite Ultimate EP Build/Modifications since I don't want to do a whole build thread since it is not a complicated plane. But there seems to be alot of mods being done. Soooo, I may pull some of them together here.
Feel free to post your ideas/pictures/comments (like everyone doesn't do whatever they please here anyway.)
Oh, and I am posting this in the parkflyers forum--and not the foam/3d/aeroabatic forum--since I plan on little heavier and tougher build. I want it for pattern aerobatics, and G.Hicks has said many times it has to be light for 3d. BTW you can chat with him at RCuniv in his forum. I will incorperate several of his suggestions as well.
The pic to the right is the stock ad photo. We'll see how close I come.
--the brute
Dec 22, 2004, 03:04 PM
Sand smooth the edges.
This is sometimes hard with depron. It gives a nice finished look, and improves the arerodynamics.
Dec 22, 2004, 03:10 PM
Landing gear mod.
I saw this one elsewhere. Using the supplied thread is just too tedious for me. A zip tie and pieces of wood. The LG seem very wimpy.
Dec 22, 2004, 03:12 PM
Next time: a big one--How to mount the tail servos. Hmmmm...
Dec 22, 2004, 05:30 PM
Tail servos
Easy way, cut holes and mount them like a shockflyer. Not so easy way, mount like suggested and find some really long servo arms.
Dec 23, 2004, 08:57 AM
Will fly for food
ON my Tribute, I had to do long servo arms for the tail servos to get the throw required. I used a couple of standard Futaba arms. I cut all the arms off of one of the micro small X armed arms. I pressed this into the Futaba hub and used soem thin, then some medium CA to attach. This gave me a longer arm that fits micro servos.
I am surprised that some manufacturer isn't offereing some longer micro servo arms. I would buy a BUNCH.
Dec 24, 2004, 08:53 AM
Servo mounting and wing reinforcing Mod
I am surprised too that they didn't include long servo arms. I put them through as suggested.
I also used wedges of foam to stiffen up the wing surfaces.
Dec 24, 2004, 08:55 AM
I have heard of people using triangle balsa stock for this purpose too.
Here is the stabilizer support.
Oh, and have a Merry Model Christmas!!!!!!!!!!!!
Dec 27, 2004, 09:16 AM
Aileron servos Mod
Manuel says on lower wing . Hicks says on top wing. Top wing mounting should make it easier to get my Vertical CG correct.
reasoning: if you mount the battery up high and need more weight above the thrustline it may be hard to move some of the other radio gear.
Dec 27, 2004, 11:51 AM
Aileron connection rods Modification
The instructions are WRONG in my opinion. Turning around a control horn fixes the problem. What is the problem you ask. The e-flite way the upper and lower ailerons do not move the same amount.
Dec 28, 2004, 11:52 AM
Battery hold-down mod
I designed this holder so I could easily adjust the battery position for and aft, and so the battery would come loose during a crash and not ruin the plane.
I consists of a velcro strap and a rubber base. The rubber base is sticky so that the battery does not move unless a violent tug--crash. The rubber is actually tape. See pic.
Dec 29, 2004, 02:15 PM
Landing gear mod #2
The gear is way too wimpy. It spreads apart just sitting there. This mod consists of a piece of wire held on with thread and CA. This holds the rubber bands in the right spot.
Dec 29, 2004, 02:18 PM
This next one is detailing, not really a mod.
Adhesive checker board.
Dec 29, 2004, 02:49 PM
Great thread, I've been thinking about moving my servos from the bottom wing to the top as well and moving them closer to the ailerons.
I agree, I had to swap my control horns around a few times to get them to work right.
It's a great flying bird, love the way it just floats around in a harrier.
Dec 29, 2004, 02:50 PM
BTW, the checkers are cool, did you use a sharpie or is that checker board trim tape?
Yippee! E-Flite Tribute EP Build...Help! ptdude 3D Flying 1 Aug 26, 2004 07:02 AM
Yippee! E-Flite Tribute EP Build...Help Please? ptdude Foamies (Kits) 0 Aug 25, 2004 03:04 PM
Horizon E-Flite Ultimate EP 3D Profile Indoor aerobatics AMCross Product Announcements 2 Apr 30, 2004 09:00 PM
Horizon E-Flite Ultimate EP & Tribute 3D AMCross Product Announcements 0 Apr 30, 2004 08:12 PM
Horizon E-Flite Ultimate EP 3D Profile Indoor aerobatics AMCross Product Announcements 0 Apr 30, 2004 08:10 PM
