Jan 08, 2019, 01:43 PM
First flight with 35gr of ballast due to stormy conditions in Germany today.
No problems at all :-)
Wing withstands even hard launches into the wind.
Day after tomorrow should be calmer....
Jan 19, 2019, 08:21 AM
I have some new things to show and to tell about AURI, But first take a look at this short summer video of it flying at the beatiful place nearby my town.
Enjoy
AURI DLG (3 min 24 sec)
Jan 23, 2019, 04:11 PM
Hi Dmitriy, please tell me...
Jan 30, 2019, 04:26 AM
Electronics and RC
MegaTesla's Avatar
And here are some photos of molds taken while manufacturing for you Robert
That mirror finish is amazing!
Did you wet sand in one direction before polishing? With what grit number did you start?
Jan 31, 2019, 11:58 AM
Hi guys here is the presentation of the AURI kit
Présentation Auri F3K Ld models (7 min 27 sec)
I finished editing yesterday mine, I filmed all the construction I will make a video of it!
Feb 08, 2019, 12:56 AM
What a crazy start of the year. Too many hours spent at the factory. And I'm hardly find the time to open internet.
Thanks to all responses and feedback from all pilots.
We did some changes to light version construction.
Ailerons now are made of 65 fiber while main part of the wing has still 39 fiber.
No flutter now even at full power launches. Ailerons are stiff, hinge line is also much stronger.
The weight of the light wing is still 10-15 g less than standard version.
Description: Name: IMG_9625.JPG
Description: Name: IMG_9655.jpg
Description:
We also modified fuselage construction a little and glass tails has some reinforcements. Will post some pics later.
The next step is reinforced spar. We are testing different versions now.
Feb 08, 2019, 12:58 AM
As far as I remember first was 800, then 1000, then 1500, then 2000
Feb 08, 2019, 08:13 AM
Neil Stainton's Avatar
They look great! Well done for the continuous improvements.
Are any of those wings destined for HyperFlight?
Neil.
Feb 08, 2019, 03:48 PM
New Product AURI F3K Competition Model
A photo of how we did the 4 pcs BlueBird Servos inside the pod.
Just flew the maiden yesterday with a lot more flights today and I must say,
after flown most of the top ones, this is second to none..!!
RTF weighing at 232g (8.1 oz)
Using a 1S-500mAh battery and no need to add any lead.
Alberto
HobbyClub.com
Feb 12, 2019, 01:29 AM
Neil.
Next batch of light models will be for you Neil
Feb 12, 2019, 01:30 AM
Alberto
HobbyClub.com
Alberto, what do you use for aileron's pushrods?
Feb 16, 2019, 09:16 PM
Dmitriy:
OK, here is: 1.2mm piano wire supplied with the kit and a 1.0mm c/f rod, both tightened
together with a piece of kevlar thread and CA glue.
Alberto
Feb 19, 2019, 02:46 PM
Zé Povinho's Avatar
I was reading the setup for this plane. I note that, unlike the planes I have had, the launch setting has reflex instead of camber. Does it make a difference in this plane? Thanks.
Feb 20, 2019, 02:38 AM
The wing is milled in thermal mode, not in cruise(distance) like some others.
That's why it's necessary to keep ailerons up a little during launch.
