This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Aug 30, 2018, 07:40 PM
old4570's Avatar
Jumper T8SG Part 2 and a little more
Jumper T8SG Lite sent for review by Banngood
So where are we ?
The Gimpy Gimbals ..........
Ok ,,, so I pulled out the gimpy G ..
Once the screw were loosened the gimbals was just fine ..
I tried to find some washers to raise the gimbals assembly so that it would not rub against the Tx case ( Which it was doing )
I could not find any , so I had to make some ( rubbish ones ) ..
Well the washers I made simply exasperated another problem ..
Seem the board the gimbals is mounted on was warping when the screws were torqued down ..
So I threw the washers away , got out a knife ..
And gouged the hole for the gimbals larger
Yeah , no more rubbing -
Still there was the issue with the warping of the board the gimbals is mounted to ..
I played with the mounting screws and ended up deleting two ...
So now there is one screw at the top on one side and one screw at the bottom on the other side ..
No more warping , no more binding gimbals ..
So I assembled the Tx , put in some batteries and tested to make sure I had not killed anything ..
Next I will bind to something ( quad ) and see how the Tx handles ..
So the gimbals are the stuff of Toys , not adjustable .
Just have to wonder ?
So the T8SG Lite is ready to be bound to something .
The plus part !
I ordered a T8SG Plus ( Paid for it - wanted one for a long time )
So now I have something I can directly compare the T8SG Lite to ( Yeah - it's DAD )
T8SG Plus ..
Bound to two micro quads at the moment ( ATM )
Eachine E010 ( MJXQ / E010 - protocol )
Eachine H8 ( Bayang protocol )
Just finished a flight @ 10mw and will see how low I can go . ( It's raining outside )
I even remembered how to set up throttle cut
Discussion Jumper T8SG Multi-Protocal 2.4G 10C Tx for Frsky Futaba Flysky DSM2 Walkera Devo biomecanoid Radios 3 Aug 13, 2018 04:03 PM
Discussion Jumper X68T Micro FPV Whoop Racer Flight Test Review (Made for T8SG Jumper) t00nz843z Micro Multirotor Drones 1 Jun 18, 2018 04:33 PM
