Aug 19, 2019, 12:12 PM
a.k.a. Bob Parks
Does it take a 4 meter wingspan to get these low thermals? If a DLG was there could it do the same?
And do the 4 meter planes fly as slow as they look in the videos, or is it a size thing, they look slower because they are bigger?
Anyone have a video with a F5J and a DLG flying together for comparison?
BP
Aug 20, 2019, 12:26 AM
AZ Outback
Robert Burson's Avatar
If you watch the video the 4M is left behind the 3.44M Crozilla as it climbs in the thermal, so a DLG at 1.5M and 270 grams I think would easily out climb both.
Aug 25, 2019, 05:22 PM
@Rober Burson about CA, check this website "https://www.mobilesolutions-usa.com/glue" and the video to it "https://www.youtube.com/watch?v=vQyk3LWlXRs"
Sep 28, 2019, 10:46 PM
AZ Outback
First ever Chinese National F5J Event.
Congratulations to Kuan Peng as National Champion flying a Crozilla.
Oct 12, 2019, 10:50 AM
AZ Outback
The AMA sent out an email this week requesting all members reach out to their elected representatives, as the FAA is back on the 400ft limit no exceptions track, with more limitations to follow.
Really bummed,
Robert
Oct 16, 2019, 02:42 PM
Hi CroZilla owners,
may I ask you for setting values
Thanks in advance
Oct 18, 2019, 01:07 PM
Bonjour je vole à 100mm de cg peu etre un peu avant a mon goût.
Pour les débattements apparemment mais a confirmé!!! beaucoup vol avec 50% de différentiel aux ailerons, les volets ne bougent pas en ailerons, la voilure baisse de 15mm aligné.
Moi je vol avec 30mm en haut et 20mm en bas ailerons, volets 5mm en haut et 4mm en bas. Voilure 15mm en bas aligné
Oct 18, 2019, 01:08 PM
Le planeur n'est pas très connu mais je trouve qu'il monte fort dans la pompe. Qualité/prix c'est le meilleur.
Mes réglages sont à peaufiné.
Oct 18, 2019, 02:20 PM
Thank you Julien, what's about speed setting?
Oct 18, 2019, 03:32 PM
En lisse
Oct 19, 2019, 01:18 PM
CroZilla settings
what does "En lisse" mean?
Oct 19, 2019, 03:24 PM
La voilure a 0 degrés
Nov 02, 2019, 12:15 PM
AZ Outback
Just checked cg before having a tangle with a Maxa which I lost, and have 110mm, which is highly reactive to lift. However, the designer, manufacturer and pilot Nikola Francic, of the Crozilla uses 100mm, but has added 1.5mm positive decalage/incidence to the stab. So you could experiment with these parameters.
Trust me you will have fun.
Robert
Nov 02, 2019, 02:06 PM
Thank you Robert, I heard that Nikola uses 103mm CG meanwhile.
Nov 02, 2019, 02:13 PM
I'll try the CroZilla as soon as weather allows
Discussion Autodesk Fusion 360 jumo004 CAD/CAM 49 Aug 28, 2016 01:08 AM
Question To Fusion or not to Fusion? viva_peru Sport Planes 6 Dec 24, 2007 07:28 PM
Discussion aero-___horror stories-how to lose an aero ace or aero soar b-29er Micro Ready-to-Fly 68 Oct 26, 2007 04:55 PM
