This thread is privately moderated by GRW3, who may elect to delete unwanted replies.
Aug 18, 2018, 05:51 PM
Modeling Retread
That’s not a Soldering Iron, This is a Soldering Iron
I was building a Balsa USA Fokker EIII and nearing the end of the assembly. I could have gone with the plain stock gear but I wanted that EIII look. I also had to modify it to take some Top Flite wire wheels I needed to figure out how to solder larger pieces. Low and behold, Balsa USA has a video about soldering landing gear on their website. Great, I thought.
As I watched the video it showed the prep, how to get the pieces together and then the copper wire wrap. Then he got the soldering iron. It was huge, compared to the normal soldering iron. I knew then that’s what I needed to get, a big soldering iron. As I recall, he gives a watt range to look for. I found this one on Amazon.
I got it. It works great. The only the he didn’t mention was that it takes about 30 minutes to get up to temperature. There are ones with more wattage available on Amazon but they cost a lot more money.
Aug 19, 2018, 03:35 PM
Me and a guy with a mustache
babblefish's Avatar
Nice iron, but be careful of putting too much sideways pressure on the tip when soldering. These cheaper irons tend to snap off at the base where the plastic handle and metal tube meet. Been there, done that.
Aug 19, 2018, 06:34 PM
Modeling Retread
For a wire wrap job, all you have to do is get the iron in contact with copper, let it heat up and the solder will wick around. Force can’t lever thermodynamics, in this case. Other applications may need some force, for which the mass would help. If I did it his a lot, I’d get one of the $200+ professional jobs, which can be found on Amazon (easiest if you select this and look at the “also considered” group).
Discussion That's a big ballot paper -not seen one like that before. leccyflyer Life, The Universe, and Politics 60 May 06, 2016 02:23 PM
Discussion It's hard to NOT believe that this adds to the cost of healthcare logan5 Life, The Universe, and Politics 22 Dec 01, 2015 02:35 PM
Discussion Get me a decent soldering iron that I can buy parts for! Gooroo The Builders Workshop 29 Feb 07, 2014 07:20 PM
Alert What's happened to this soldering iron bit? Hogster Electric Plane Talk 14 May 20, 2005 05:41 PM
Source for a soldering iron and "hammer head" tip that will fit it? Art Horne Batteries and Chargers 5 Apr 16, 2003 08:46 AM
