This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Aug 17, 2018, 10:04 AM
Mini-Review
Warlark Pro 85 2S Tiny Whoop - DSHOT and cam fixed
Warlark Pro 85 is some time old, but you can get it on offer for about 80 € with a Frsky, Flysky or DSMX receiver. The Tiny Whoop is with 2S Lipo what makes it so interesting. With 2S power it's much faster and more aggressive when flying than a 1S Tina Whoop. Ok, the weight of 50g is of course more than a micro Tiny Whoop with 20g.
Warlark Pro 85 BNF FrSky - $91 - Gearbest
But the Warlark Pro 85 is small enough to fly through the home or garden. And that's really fun with 2S. But first to the negative points that I have fixed.
The Warlark Pro has 3 different receiver boards. My is the Flysky board which need to be updated to version 1.2 as follows:
  1. download the Programmer v 1.0 for RX flashing from overskyrc page
  2. ldownload the RX firmware 1.2 from overskyrc page
  3. press BIND button and connect USB to PC
  4. under BF go to CMD to update RX: serialpassthrough 1 57600
  5. start the programmer v1.0 and update the RX firmware
This is important to update the receiver to V1.2, otherwise no SBUS will work under Betaflight 3.5 and you will have to use PPM protocol or stay with Betaflight 3.01 without "Turtle Mode". Here is the PDF document of OverSkyRC page with all information about the three receivers - RX Bind and Update PDF file
The Warlark Pro has an OSD display. This is a MinimOSD and can only be customized via a MinimOSD GUI software. That works if you do this:
  1. press and hold BIND button and plug USB into PC
  2. under Betaflight CLI for updating OSD type:
    serialpassthrough 0 115200
  3. open MW_OSD_GUI
  4. connect to Batterie
  5. under the GUI connect to the OSD, read
  6. setup the OSD parameter
  7. write it back
To use ESC's with DSHOT600 protocol unfortunately has to be soldered. It is a small cable soldered directly to the F3 FC, which is indeed a fingertip exercise. So be careful not to overheat the FC or solder the pins together. I used solder paste and cover the other pin with a tape.
After the yellow cable is soldered, DSHOT600 can be used and the last 4th motor turns after I have entered the following commands for the 4th motor under CLI:
resource motor 5 none
resource motor 4 A06
save
In the settings under Betaflight 3.5, I let the motors turn inverted, in the opposite direction. Here you have to set the direction to REVERS under BLheli Configurator for all motors.
And of course I have the BL_Heli firmware updated to 16.7 so that I can use the turtle mode (FLIP OVER AFTER CRASH).
Binding the receiver to your remote control is easy:
  1. connect the battery to Warlark Pro
  2. press the BIND button for 2 seconds (at the back, to the right of the power socket)
  3. the LED is flashing fast now
  4. Now bind your remote control to the Warlark Pro
  5. the LED stops flashing so the binding process was successful
Now I activate under Betaflight RX serial and the RX protocol on SBUS for my Flysky receiver.
After binding I can test my transmitter under Betaflight. Note that the minimum value is not 1000 and the maximum value is not 2000. It is important that in the middle position of the gym balls the value is 1500. To correct this you can do this on the remote control or better directly under Betaflight with RXRANGE command which can adjust the min and max values for the transmitter. These are my RxRange parameters on my Flysky receiver and the Trunigy Evolution remote control:
rxrange 0 885 2054
rxrange 1 885 2064
rxrange 2 885 2060
rxrange 3 885 2056
save
The frequency of the video transmitter change is as follows:
  1. press 2x on the FR / B button then the VTX is in frequency setting mode. A short tone is heard
  2. press once to jump one frequency further according to the frequency table
  3. for the standard frequency with 5705 MHz press long until a long tone is heard. Frequency setting mode is now closed
  4. Wait 10 seconds and a long tone will be heard. Now the new frequency is stored and the setting mode is closed
In order to get a better video from the CMOS camera it is definitely worth taking the Caddx Turbo EOS1 camera. The EOS1 is the best CMOS camera in the small size 14x14x16mm with just 3.5 grams. The camera has the same big lens as the Runcam Sparrow is smaller and fits into the Warlark Pro.
Now everything is perfectly optimized on the Warlark and there are only a few settings under Betaflight to have a lot of fun while flying.
For the first flight I use the standard PID values and am very satisfied. The super rate I set instead of 0.70 to 0.60 because the Warlark Pro is very sensitive to control signals from the remote control.
Finally, motor on, set up three flight mode settings and put the buzzer on a switch. Angle Mode is a simple stabilized mode perfect for practicing. HORIZON mode can also rotate 360 degrees if I tilt 20 degrees, no matter in which direction. Acro mode is perfect for flying with the FPV goggles best where there is enough space. In the Acro mode everything is manual and requires good concentration.
Warlark Pro 85 – Gearbest FrSky , Flysky, DSMX
Caddx Turbo EOS1 – Banggood Coupon: aff7off
Turing Evolution TX – Hobbyking Coupon: HobbyKing10
Turnigy 300mAh 2S – Hobbyking Coupon: HobbyKing10
Spare parts such as propellers for the Warlark Pro 85 – https://newbeedrone.com/
And here my review at my blog site (DE lang)
https://kopterheld.wordpress.com/201...2s-tiny-whoop/
Original configuration
On the Warlark is Betaflight 3.0.1 with the following changes (diff):
# BetaFlight/SPRACINGF3EVO 3.0.1 Oct 18 2016
feature -RX_PPM
feature -TELEMETRY
feature -BLACKBOX
feature RX_SERIAL
feature MOTOR_STOP
serial 1 64 115200 57600 0 115200
aux 0 1 0 900 2100
set min_throttle = 1170
set serialrx_provider = SBUS
set vbat_max_cell_voltage = 45
set vbat_min_cell_voltage = 30
set vbat_warning_cell_voltage = 32
set align_gyro = CW90FLIP
set align_acc = CW90FLIP
profile 0
rateprofile 0
set yaw_srate = 100
my configuration from 2018-08-15
On the Warlark Pro 85 is Betaflight 3.5.0 with the following changes (diff):
# Betaflight / SPRACINGF3EVO (SPEV) 3.5.0 Aug 14 2018
name WL85Pro
resource MOTOR 4 A06
resource MOTOR 5 NONE
feature -RX_PPM
feature -RSSI_ADC
feature -TRANSPONDER
feature RX_SERIAL
feature OSD
beeper -SYSTEM_INIT
beeper -ON_USB
serial 0 1 115200 57600 0 115200
aux 0 0 0 1800 2100 0 0
aux 1 0 2 1700 2100 0 0
aux 2 1 1 900 1300 0 0
aux 3 2 1 1300 1700 0 0
aux 4 13 3 1700 2100 0 0
aux 5 28 1 1300 2100 0 0
aux 6 35 3 1600 1875 0 0
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1010
set max_check = 1990
set motor_pwm_protocol = DSHOT600
set beeper_dshot_beacon_tone = 5
set yaw_motors_reversed = ON
set small_angle = 45
set deadband = 2
set yaw_deadband = 2
profile 0
set dterm_notch_cutoff = 0
set feedforward_transition = 10
rateprofile 0
set roll_srate = 60
set pitch_srate = 60
set yaw_srate = 60
My equipment:
Fatshark Dominator HD3 – https://goo.gl/6Z9eU4
Eachine Pro58+Achilles – https://goo.gl/x4v74Z
FrSky TARANIS Q X7 Funke – https://goo.gl/NLlhjc
FrSky X9D Plus SE Funke – https://goo.gl/KlnCoS
iRangeX IRX4 Plus Multiprotokol Modul – https://goo.gl/uF6Co8
FrSky XM Empfänger – https://goo.gl/5InfW5
FrSky R-XSR Empfänger – https://goo.gl/4YM9LH
FrSky XSR Empfänger – https://goo.gl/00SGNz
Flysky FS-i6 – https://goo.gl/zUEYnB
Turnigy Evolution – https://goo.gl/tzphLP
Fli14 Plus Empfänger – https://goo.gl/cbWDKs
RunCam Split Mini – https://goo.gl/mjJWvd
RunCam Micro Swift 3 – https://goo.gl/YK9yFr
RunCam Micro Sparrow 2 Pro – https://goo.gl/A3LjgC
RunCam Micro Eagle – https://goo.gl/cqE7t6
Facebook – https://www.facebook.com/kopterheld/
Blog – https://kopterheld.wordpress.com/
Youtube – https://www.youtube.com/kopterheld
RCGroups – https://goo.gl/JYP87D
Aug 18, 2018, 05:44 AM
great post!
Sep 13, 2018, 09:55 PM
Flashing RX, can't do button
Glad to see this article!!
I couldn't flash RX. Always times out. I tried many combinations of "press BIND button and connect USB to PC" but could not figure it out. I tried click and release then plug in, click-and-hold while plug in, with and without battery... What exactly did you do?
Sep 14, 2018, 01:25 PM
can help me I can not bind with my transmitter Flysky When I got the Drone I was able to do the bind I made up a flight with it only that I went to change the alarm of the battery and stopped working the communication of the transmitter with receiver so I tried to update the firmware of RX but it is giving invalid the port that this Drone connected then I can not update the firmware of the RX I tried also to update the betaflight for 3.1.7 but it did not resolve then I returned to the 3.0.1 zero point and I put the factory settings of the Drone anyway still has not resolved vie in topic that could be the configurator version of betaflight so I tried with version 3.1.1 of betaflight configurator but it did not solve it can help me I will send some videos for you to see how are the problems.
Warlark pro (0 min 52 sec)
Desktop 2018 08 30 16 07 15 01 (1 min 27 sec)
Warlark pro (1 min 25 sec)
Warlark (0 min 33 sec)
Sep 16, 2018, 04:01 PM
For flashing the Flysky RX use this Video 4 from leinho77 user.
1. press BIND button and hold it.
2. connect battery to drone. (blue LED is flashing slow)
3. wait over 2 sec , the LED lights up permanently
4. start the programmer v1.0 and update the RX Firmware
Sep 16, 2018, 04:02 PM
[QUOTE=leinho77;40222154]can help me I can not bind with my transmitter Flysky When I got the Drone I was able to do the bind I made up a flight with it only that I went to change the alarm of the battery and stopped working the communication of the transmitter with receiver so I tried to update the firmware of RX but it is giving invalid the port that this Drone connected then I can not update the firmware of the RX I tried also to update the betaflight for 3.1.7 but it did not resolve then I returned to the 3.0.1 zero point and I put the factory settings of the Drone anyway still has not resolved vie in topic that could be the configurator version of betaflight so I tried with version 3.1.1 of betaflight configurator but it did not solve it can help me I will send some videos for you to see how are the problems.
Hi leinho77,
For flashing the Flysky RX use your Video 4
For Binding use your video 1
1. connect battery to drone. (blue LED is flashing slow)
2. press BIND button for 2 sec. (blue LED is flashing fast)
3. start Bind with your transmitter
Good LiPo battery for the warlarks is the
Turnigy 300mAh 2S Akkus – Hobbyking Coupon: HobbyKing10 - https://goo.gl/65Fbys
good flight,
Kopterheld
Sep 16, 2018, 11:26 PM
my receiver had to update with my computer could not was just change the computer that resoveu the problem I updated the receiver ja ok ok. thank you so much.
Sep 21, 2018, 10:19 PM
Ends up what was important for me was ensuring the board was "change the receiver signal mode to PPM" and that "Choose actions:" would appear after the serialpassthrough was set. Those were from the iffy PDF manual, and they helped me get past that point in your posted instructions.
What does soldering the two pins together actually do? Seems like voodoo without the explanation.
May try the fine point soldering and camera replacement. Ordering parts.
Thanks for the info about the Warlark. There's not enough around.
New Product Warlark Pro-85 brushless FPV whoop 48g! YXmotor Micro Multirotor Drones 200 Dec 21, 2018 12:53 PM
Alert Warlark Pro 85 85mm Frsky BNF Brushless Whoop Now Only $69 fastmax Micro Multirotor Drones 6 Jul 01, 2018 11:41 AM
New Product Warlark Pro - 85 85mm Micro Brushless FPV Racing Drone - BNF Gearbest Mini Multirotor Drones 4 Apr 27, 2017 05:38 PM
