This thread is privately moderated by RightBrother, who may elect to delete unwanted replies.
Aug 14, 2018, 08:00 PM
EPP Foam Delta Wing Takeoff and Landings with Nose Wheel
Added little nose wheel to drag out landings a bit. Seems to land nicer than and with less shock than just a skid. Now want to raise the nose wheel to give prop ground clearance to see if delta can take off from the ground. May have to change motor and prop to give it more thrust.
Update: I raised the nosewheel to provide clearance for the prop- did takeoff from the ground. It worked but was so unstable in the air that I clipped the nosewheel on the ground and it broke off. Wish I had videoed it - was funny and cool at the same time. Will glue it back on and try video sometime.
Delta Take Off and Landings With A Nose Wheel (2 min 16 sec)
New Product New Elite Series 39in 15mm EPP Foam Sbach-342 from Value Hobby with Airfoiled Wings Value_Hobby 3D Foamies 8 Sep 19, 2021 06:35 PM
Discussion HK Phazer Delta Wing w. Optional Landing Gear and Steerable Nose Wheel IFlyRCs Foamy EDFs 392 Mar 23, 2020 10:54 PM
Video Takeoff and landings with the STM DHC-2 Beaver on gras. BjarneKvilvang Electric Plane Talk 0 Aug 06, 2017 09:36 PM
Delta Wing with wide nose dst Flying Wings 9 Aug 30, 2005 06:55 PM
