Concerning the paint scheme: Jiri B. can paint the Escape V2 in every color scheme you want.
It's not a stock model, every plane is moulded especially for the customer. |
Have you contacted him via these? http://jiri-bacinsky.kvalitne.cz/kontakt/ |
What are you planning to power yours with? Post some pics when you get it! |
Looking at these: https://www.reisenauer.de/aid-1525-P...n-5-1-N-T.html https://www.reisenauer.de/aid-1526-P...n-5-1-N-T.html |
Why not run inrunner with gear drive. High speed the inrunner will be more efficient.
Try dd in an outrunner with kv that matchrs the geared setup final speed. On a geared setup like that what is the output shaft speed at WOT on cells u run. |
Video of the Reverb
Nice video. I think if I was doing a geared setup id rather have a 4400 kv inrunner because in most cases the inrunner will be more efficient in high rpm applications.
I think the benefit of the Peggy Power setup is the weight saving, seen a few vids of that setup and it seems to go very well
Nice, I like that the canopy/pod got painted with the black fuse. Will you post any build or flight reports? Some vids would be good if you can.
I've put my plans on hold due to having surgery on Monday and recovery means I cant drive for about 3 months, basically my flying season is over this year and I'm unlikely to fly until March or April |
I received my Escape V2 today. Very well packaged, very little risk for transport damage.
Some photos and measaurment All in metric :-) |
I mentioned earlier that I was thinking about the Peggy 2221 (28mm in diameter). And I think it will fit without the wires touching the motor.
Here is a photo with a Peggy 2524 whick is 31,5mm in diameter. But I would like to know your suggestions for setup. All I require is that it uses a Resien Micro Edition gearbox since I have a nice PNC motormount for that gearbox I want to use. I have decided I want a gearboxed pylon setup to avoid the high pitch sound and it should do atleast 200mph. Give me your best setup suggestions :-) |
Hi my name is Jiří Bačinský. I am the manufacturer of Escape V2.
This is broken old page : http://jiri-bacinsky.kvalitne.cz/kontakt/ New page ist : https://f3x.mypage.cz/menu/pylon-escape-verze-2 I sold the old Escape molds to Jiří Huek. Molds repaired and manufactured old version of Escape. His page is: https://www.jiri-model.cz/ I wish you many good flights and landings. |
Looks good, thanks for the pics. Seems to have a nice battery area and most 4s 2200 will fit once you open the hole up a bit. Can't advise on 200mph+, be interested to see what you use
Thread Tools | |
Similar Threads | |||||
Discussion | Best Service from Jiri Baudis | jyrmex | Scale Sailplanes | 2 | Mar 28, 2018 09:53 PM |
Discussion | Shoplifter escapes by using fecal attack. | ckimmey | Life, The Universe, and Politics | 0 | Feb 16, 2018 11:32 PM |
Discussion | Escaped inmate may have used wire cutters delivered by drone | Miami Mike | Chit Chat | 1 | Jul 08, 2017 05:35 AM |
New Product | Extasy F3B by Jiri Tuma/Günther Aichholzer | gliding Oz | Multi Task F3X | 108 | Nov 24, 2016 11:22 AM |
Question | searching for Jiri Kalina kits | StephanB | Scratchbuilt Indoor and Micro Models | 7 | Jan 10, 2006 02:53 AM |
