This thread is privately moderated by bill_delong, who may elect to delete unwanted replies.
Aug 10, 2018, 07:48 AM
Did I make the A Main?
bill_delong's Avatar
Mini-HowTo
How to wire HV Servo from 2S LiPo
Be sure your wiring to the servo is such that only the +8.4v positive lead is the only wire coming from your LiPo into the servo... you want the signal lead and true negative to come from the ESC like this:
I sell these wiring harnesses for $5 each + $3 shipping for folks who don't want to mess with soldering.
Here's an example of what happens if you use both the negative and positive lead from the LiPo to servo:
Demo HV Servo off 2x2S LiPo in Series (2 min 49 sec)
Here's an example of the wiring which is wrong, do not use this method which is what I used the video example above that was prone to glitching at full throttle:
Check out more stuff on My Bookmarks page!
Aug 10, 2018, 06:59 PM
More Motors, More Fun... :-)
nioa's Avatar
Hi Bill, the lipo connector you're using in the first image may not hold up well under repeated insertions. There is only a tiny bit of plastic holding that pin in. It will eventually wiggle out of the housing.
A better way to do it is to mount the lipo connector to a small PC board. This gives more mechanical support, and lets you use a spot of glue to fixate the housing better. It also provides a nice solid place to solder the wire to. Wrap it in heatshrink, and you'll have a reliable connection.
Nick
Aug 10, 2018, 07:13 PM
Hi Nick, Thanks for the suggestion, any chance you have a pic which details your explanation?
I'm not following how to mount it to the PC board in a way that is re-usable?
I normally don't use this particular connector in my cars, I typically splice solder into the ESC input voltage, but I made this harness as a means to make it easier for folks to get HV servos working without having to solder anything themselves
Aug 12, 2018, 12:58 PM
nioa's Avatar
Here is a pic of something similar. Obviously the PC board is much larger than needed, but it should steer you in the right direction.
Let me know how it turns out.
Nick
Aug 12, 2018, 02:19 PM
very interesting, I like that approach!
Aug 17, 2018, 06:07 AM
help about study
I tried making connectors on my own and powering the servo but they went loose after some time. I asked for it on essay help in uk but no help unless I came across this article. Thank you for sharing it.
Discussion replace 2 wire servo by 3 wire servo .. how abdahorn Rock Crawlers 1 Sep 06, 2017 12:00 PM
Question 2s LiPo and HV servos with 4s Lipo/Motor Hugh Shiel Power Systems 6 Jul 09, 2016 12:30 PM
Question Futaba HV servos with 2S lipo ??? khaled_abobakr Radios 4 Jun 17, 2014 09:08 AM
Discussion How do I wire a 2S lipo for use in my 18MZ? ZyBeR Radios 1 Mar 06, 2013 06:51 AM
