This thread is privately moderated by Prof100, who may elect to delete unwanted replies.
Aug 09, 2018, 11:44 AM
Prof100's Avatar
Induxtrix Pro small Quad 8-11-18
11-1-18
Josh Bardwell video that explains how to adjust your tiny whoop for drifting by simply using stick movements.
Calibrate & Trim Betaflight Tiny Whoop Accelerometer | HOW TO FIX ANGLE MODE (14 min 19 sec)
9-28-18 UPDATE
Ordered three sets of 19600 kv motors for $6 clearance price from A main hobbies.
https://www.amainhobbies.com/racetek...tk2511/p612319
RaceTek CL-0615-19 TinyFPV "Stage 3" Motor Set (19,600kV)
Flight in backyard on a calm September evening.
9 23 18 Ind pro backyard 5 (2 min 44 sec)
8-18-18 The HH tech support “No trouble found” Inductrix Pro returned / arrived home today. I bound it again and it flew. Tech support reminded me of the need to turn on the TX and let it initialize before plugging in the battery. I did, but the next time I cycled the radio and installed a fresh lipo the motors would not run with the throttle cut in the power on position. I found that I have to cycle the throttle (off-on-off-on) to get the motors to run.
IMPORTANT NOTE: Each flight requires removing the lipo. Cycling the radio and then placing kill switch in the off position. Turn radio on, let it initialize, plug in lipo, move the cutoff /disarm switch to arm. Then, go fly. If it won’t arm repeat.
Expo set to 35
Dual rates set to 90-75-60.
Adding expo and dialing down the dual rates makes it more flyable in my rookie to whoops flying handa.
8-16-18 HH tech support declared no trouble found when the were able to repeatedly bind my Inductrix Pro with a DX9 they had available. Mine is a DX8 Gen1. Then they tried to tell me it was perhaps my radio. My DX8 has 27 planes bound to it. They said I should send the radio back as well. I call BS.
8-08-18. Induxtrix Pro arrived and it was defective. It would not hold bind. Called HH tech support and said it must have a bad board. Sent it back with prepaid FEDEX shipper. Dexter at tech support said it would take 2 Weeks.
Bought the small FPV quad to learn FPV. Price was $80. Setup instructions for the transitter had nothing for my Gen 1 DX8. Found the below video on line that explains radio setup.
Bit wordy but it covers Gen 1 DX8 setup.
How to bind Spektrum DX8 to Blade Inductrix FPV Pro (14 min 14 sec)
Switch selection is key.
Last edited by Prof100; Nov 01, 2018 at 08:51 PM. Reason: Adding stick movement drift adjustment
Discussion Small DLG for small person (8 year old) belouder Hand Launch 23 Feb 22, 2016 07:16 PM
Help! Firmware ESC tower pro MAG 8 18 A faraone Power Systems 3 Jun 26, 2012 04:47 PM
Discussion GOLD $1,435 an Oz.....7/18/11 now $1,600 an oz. 8/8/ 11 now $1.700 an oz. realtimerecon Life, The Universe, and Politics 136 Sep 05, 2011 03:54 PM
Build Log Small Micro Quad only 11" across @175g(The Ripper) Z06 Tony Multirotor Drone Talk 42 May 25, 2011 07:26 AM
