Aug 09, 2018, 08:05 AM
Eagle Tree Antenna Tracker Video problems
Hello,
I have the eagle eye antenna tracker with the HITech HS 645-MG.
As soon as the tracker begins to track the model, I have to strip in the video image.
If the tracker does not move, the stripes are not present.
In addition I use the Immersionrc 5800 duo.
I heard you have to power the servos via an external BEC to solve this problem .. does anyone have an idea?
Greetings from Germany
Aug 10, 2018, 08:26 AM
JohnET's Avatar
Hello,
You may need a filter or you may be over-stressing the Eagle Eyes 5v regulator with those servos and your particular tracker/antennas. Try powering the servos from an external BEC instead of the Eagle Eyes or adding a filter. See the troubleshooting section of the manual for details on both. If you can not get it working correctly, please open a support ticket.
Regards, John
Article Eagle Tree Antenna Tracker Tutorial - RCGroups FPV Video Review Matt Gunn FPV Talk 17 Aug 22, 2017 05:11 PM
Question Help MFD antenna tracker with eagle tree Vector Heliquejo FPV Equipment 5 Nov 06, 2016 11:03 PM
Discussion Eagle tree antenna tracker CHUDDY FPV Equipment 0 Apr 20, 2015 01:49 PM
Link Antenna Tracker with Eagle Tree morhon FPV Talk 0 Nov 19, 2012 04:08 PM
Discussion RMRC Eagle Tree Antenna Tracker Mod!! flyn Eagle Tree Systems 0 Aug 12, 2012 05:32 PM
