Aug 08, 2018, 06:57 PM
Thermals, Tom
RyanNX211's Avatar
Cool
Four Stroke diesels
These are so fun. Laser had a short run of them but they’ll cost you a lot if you find someone willing to part with one.
This O.S .52 of mine was converted by Diesel RC.
http://www.thebuildingboard.com/2018...st_21.html?m=1
Latest blog entry: Steak and Old Timers
Aug 08, 2018, 06:59 PM
Thermals, Tom
RyanNX211's Avatar
I gave my dad one of the Enyas for his birthday. It has
a fixed compression but that never seemed to be an issue.
ENYA 41-4C diesel engine R/C 6,64 cm3 (3 min 46 sec)
Aug 08, 2018, 07:03 PM
I TOBOR's Avatar
This is a Saito .80 running on Davis Diesel fuel. It is turning a 13.5 x 8 Bolly Clubman prop at 8,792 and idling at 1,541. The only mod is removing the coil from the glow plug.
Aug 08, 2018, 07:09 PM
Thermals, Tom
RyanNX211's Avatar
Their last 4 Stroke Diesel was a 36.
Good luck finding one.
ENYA 36-4C-TN Diesel (14 min 39 sec)
Aug 08, 2018, 07:20 PM
Thermals, Tom
RyanNX211's Avatar
I wonder what the compression ratio of your Saito is.
Aug 09, 2018, 01:27 AM
surfer_kris's Avatar
There always seems to be a lot of knocking in the fourstroke engines though, especially during acceleration. I haven't seen anyone that runs as smooth as the two strokes can do:
MVVS .09 Diesel #2 (9x4 prop) (0 min 52 sec)
Aug 09, 2018, 03:13 AM
Thermals, Tom
RyanNX211's Avatar
I don’t have an explanation
Aug 09, 2018, 03:49 AM
I don't know the reason either, but that is perhaps why they were never produced in any big numbers....
Aug 09, 2018, 05:50 AM
I TOBOR's Avatar
It's compression ratio is 15.5 to 1, it is fairly quiet when peaked but when set a little rich it's quite clattery. Here is something you'll all think is backwards but on a 13x6 it will only turn 5,500 and no matter what you do it sounds like it's going to explode but when loaded with the 13.5 x 8 it runs at 8,700+ and is very smooth.
Aug 09, 2018, 06:40 AM
The great Brutifier
IMHO not backwards at all… I think it indicates a bit too early ignition for the load.
Maybe too high compression or too much ether?
Aug 09, 2018, 07:21 AM
LARGEST is SELDOM best
Gary Cee's Avatar
Probably as you said Bert.
That makes adjustable compression a desirable option. More easily accomplished with a typical two-stroke/cycle system.
Aug 09, 2018, 07:38 AM
Engine man
dmrcflyr2's Avatar
https://youtu.be/DClj96aCTnw
The rocker cover is installed backwards on this engine....
Why would you need to find one? If Dave just removed the element from a glow plug and ran his Saito 80, you could do the same thing with any 4 stroke engine. I might just have to give this a shot.
Aug 09, 2018, 08:27 AM
Gary Cee's Avatar
Dave didn't say but that may have been an older high compression model. Saito quickly dropped the C/R on that model after the original release.
Aug 09, 2018, 09:01 AM
Engine man
dmrcflyr2's Avatar
Yes, Dave's is an older 15.5:1 CR engine.
Aug 09, 2018, 09:21 AM
Thermals, Tom
RyanNX211's Avatar
Might be for clearance. The 46 won’t run with it on.
Diesels are beefed up if made as diesels. Also, variable compression is nice.
Discussion Live Diesel Locomotive with OS FS 40 Four Stroke nitro Engine stevster Engines 14 Jun 21, 2018 11:33 PM
Discussion 3D Planes...Two Stroke or Four Stroke Engine??? Eugene Chernosky Fuel Plane Talk 65 Aug 27, 2017 04:47 PM
Discussion Two stroke or four stroke roslyn Classic Pattern Flying 18 Oct 26, 2016 08:30 PM
Discussion Four stroke flat diesel engine Feliks Engines 10 Mar 27, 2011 10:21 AM
Discussion When was the first four cycle/four stroke for R/C? fourcycle Engines 20 Apr 04, 2009 01:29 AM
