Aug 07, 2018, 05:43 AM
Quad Erat Demonstrandum
scousethief's Avatar
EZTŪ T1-M+L Delta Kossel 3D Printer DIY Kit 300*320mm Large Printer Size With Laser E
https://www.banggood.com/EZT-T1-ML-Delta-Kossel-3D-Printer-DIY-Kit-300320mm-Large-Printer-Size-With-Laser-Engraving-p-1334102.html
Im looking for a new 3d printer with a larger printing bed ( currently a heavily modified Anet A8) this is one of my options and fits within my budget. Lazer engraving is a bonus i suppose.
Features:
1. T1-M+L 3D Printer DIY kit is upgrated to T1 3D Printer model. Support laser engraving. And coming with 1kg PLA filament for free.
2. 300*320mm Larger printing size, large printing size.
3. Supprot intelligent leveing, Only 4 steps to chieve.
4. With ARM 32-bit motherboard, upgraded mainboard
5. With LCD screen, it can support multi-language for optional. Can meet different needs
6. Support auto change filament, safer and more concise to use
7. The product have obtained CE,SGS,EMC, FCC and RoHS Certificates.
8. With fast modular assembly, easy for you to assemble and install.
Specifications
Model T1-M+L
Engraving Area 180mm
Engraving Accuracy 0.01
Print size Φ180 (circle diameter) Ũ 320mm
Printing Precision Z axis: 0.004mm; XY axis: 0.012mm
Frame material Acrylic plate
Platform board Aluminum Base
Nozzle quantity Single
Nozzle diameter 0.1-0.4mm
Nozzle temperature Room temperature to 250 degree
Layer thickness 0.1-0.4mm
Print speed 20-80mm/s
Platform temperature Room temperature to 100 degree
Supporting material ABS,PLA,PA Wood,Marble,Flexible PLA
Material diameter 1.75mm
Control Temp Extruder: Max 260°C; Hot Bed: 50-100°C
Recommend Temp PLA: Nozzle:210 °C Hot Bed: 50 °C
ABS: Nozzle:230 °C Hot Bed: 80 °C
LCD Screen TFT1.44"
Memory card offline print TF card
Language Chinese / English / Russian / German / Spanish / French / and other multi-language switc
File format .STL/.OBJ/G-code
Model supporting function Yes
XY-axis positioning accuracy 0.012mm
Z-axis positioning accuracy 0.004mm
Laser printing 450nm 1000mW 12V High Power TTL Adjustable Focus Blue
Power 100~250V, 200W
Power supply
Plug EU Standard(Default)
Host computer software ReplicatorG,Repetier-Host,Cura,Simplify3D,Slic3r
Packing Type Assembled packing
System support Windows/Win7/Win8. Linux Mac
Laser Lifetime 1000-1500h
Laser Wavelength(nm) 450nm
Current (mA) 1000
Certificate CE,RoHs,FCC,LVD,VDE
Machine Size 350*380*700mm
Packing Size 750*400*110mm
Package Included:
1 x T1-M+L 3D Printer DIY Kit
1 x 1KG PLA filament
Dec 21, 2018, 02:57 PM
oh my! This thing is a headache!!!!
Mini-Review Anet A8 Cheap ($194) DIY 3D Printer Kit Review - Great Bargain Alwaysbless 3D Printing 8 Apr 13, 2017 10:41 AM
Alert Amazing deal on a large size 3D printer downloader9 3D Printing 5 Jan 06, 2017 11:56 AM
Discussion Stella Models Delta printer. (Kossel) TurboCinqy 3D Printing 6 Nov 24, 2015 11:56 AM
