Aug 06, 2018, 09:43 AM
Fan Fold Foam
I've been out of the r/c foamy loop for several years. Did a lot of building with the dow blue fan fold foam. Is it still available, if so where.
Thanks, Rick.
Aug 06, 2018, 09:58 AM
treefinder
springer's Avatar
You can check whether you have an Allied Building Products in driving distance. They are nation wide and carry all the Dow products. Or you can check out modelplanefoam.com
Aug 07, 2018, 07:10 AM
flyin' fool
goldguy's Avatar
FFF a thing of the past. MPF the same thing, only white, flat and no skin.
Aug 07, 2018, 08:04 AM
Retired CAD guy
birdofplay's Avatar
In the Midwest Menards still has Pink Fan fold foam.
If A Pink Plane is what you actually want.
Aug 07, 2018, 09:56 AM
Good looking Cook+Maid needed
flyerdave's Avatar
https://www.menards.com/main/buildin...0647302&ipos=3
Aug 07, 2018, 02:19 PM
Hey, watch this!
Raymond-leflyr's Avatar
I've converted to www.modelairplanefoam,com. or is it www.modelplanefoam.com
Lowes of Home Depot around here in North Carolina sells green stuff that is similar - although more brittle.
Aug 08, 2018, 10:38 AM
daydreamer's Avatar
does any one have the SKU # for it
Aug 08, 2018, 11:57 AM
Retired CAD guy
birdofplay's Avatar
Do not even bother with the green stuff of any thickness.
Aug 08, 2018, 07:08 PM
Jack
jackerbes's Avatar
Not sure if the Dow Protection Board III (FFF) is a discontinued product or if home Depot simply does not carry at some or all stores. It no longer comes up in a product search on the Home Depot pages. It looks like it has been replaced by this Owen Cornings product:
https://www.homedepot.com/p/Owens-Co...21UM/100320301
They say that it is in stock at my local store, maybe I'll drop by and look at the stuff. I don't need any of it, I still have most or all of a lifetime supply of FFF as we knew it down in the basement...
Attached is the MSDS for FFF, it may help you find it or order it somewhere...
Jack
Aug 09, 2018, 05:31 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Well it’s not like FFF goes bad ( in storage) …A friend offered me a whole bundle of Blucor to continue my building activities …I still build for others ...
Latest blog entry: Lost plans
Aug 10, 2018, 12:37 PM
ski bum
Yes, as long as you keep it out of sunlight. I learned this the hard way.
Aug 11, 2018, 08:57 AM
Jim
I agree. It will fly, but looks like $h!t and is difficult to build with! JMO
Blue Baby 33..Lowe's green FFF (plans available on rcgroups.com in the "scratchbuilt foamies" forum. (1 min 25 sec)
Aug 11, 2018, 03:15 PM
Out Standing In The Field
RexGalore's Avatar
LOL - the first thing I thought of while watching that video was "those trees on the left sure look hungry ".
Latest blog entry: Rare Bear
Aug 12, 2018, 10:49 AM
Jim
Aug 14, 2018, 03:09 AM
ErcoupeEd's Avatar
Have any of you gys read Keith SParks "Building With Foam?"
Excellent references on building light weight strong foam airplanes.
He also has several foam kits out now.
Using his methods I am going to start ona 96 inch Monocoupe 90A.
I ordered two sets of plans, will use one set for patterns, build on the second set
Also I just received two sets of 100 inch wing span T28 Trojan plans.
PLan on doing the same thing.
Projected AUW will be less than half of an all wood model.
Plan on using electric power.
Purchased an adequate supply of 1/2 inch foam, 3/4 inch foam and 2 inch foam and a set of fanfold foam from Menardsa.
I have a Tekoa Feather Cut foamcutter with all of the accesories for cutting cowls, , round parts, etc.
I figure I can build the Monocoupe for less than 1/3 the cost of a wood kit, plus be much lighter in AUW
Should build much faster also.
Discussion FOAM, Blue Fan Fold vs Foam Board, Which is better?? Ben Flying Foamies (Scratchbuilt) 14 Aug 16, 2017 02:00 AM
Question C A for depron & blue fan-fold foam ?? 14532924 Foamies (Scratchbuilt) 0 Jun 18, 2017 11:09 PM
Build Log FOAM, Blue Fan Fold vs Foam Board, Which is better?? Ben Flying Electric Plane Talk 0 Jan 11, 2017 11:34 PM
Discussion Kingspan Insulation Faced Polystyrene Foam Board Fan Fold JimHSoars Foamies (Scratchbuilt) 7 May 06, 2016 06:56 PM
What is good for Fan Fold Foam Foam Gap Filling? RC Pete Foamies (Kits) 4 Jul 21, 2002 12:29 AM
