Oct 16, 2018, 08:36 AM
Bill Glover's Avatar
Originally Posted by HuffDaddy
actually connect flight battery while USB cable is connected to the laptop?
ok but I thought was a no-no
Remove the props, or fit a 'smoke stopper' between pack & quad (this limits the maximum current).
Latest blog entry: Eachine QX65 FPV quad review
Oct 16, 2018, 08:38 AM
You're using the wrong configurator. That one is for BLHeli_32 only - BLHeli and BLHeli_S use a different version.
Oct 16, 2018, 09:40 AM
I kill batteries!
There is blheli suite (32 and non-32) and there is blheli configurator.
As far as I know configurator is still a google chrome app so you have to search and install it through google chrome browser.
Oct 16, 2018, 10:04 AM
Sorry I meant BLHeliSuite, which is what HuffDaddy was using. This is a downloaded/installed application (as you know).
Oct 16, 2018, 12:41 PM
I kill batteries!
You are correct as well. I was just pointing out the difference to huffdaddy
Oct 16, 2018, 09:21 PM
No Guts, No Glory!
HuffDaddy's Avatar
thanks for your tips guys... is this the correct BLHeli?
I must have connected the USB cable a dozen times waiting a minute or so in between... it connects then throws this error
2018-10-16 @ 19:05:56 -- Running - OS: Windows, Chrome: 69.0.3497.100, Configurator: 1.1.0
2018-10-16 @ 19:06:12 -- Serial port successfully opened with ID: 5
2018-10-16 @ 19:06:13 -- MultiWii API version received - 1.36.0
2018-10-16 @ 19:06:15 -- Flight controller info, identifier: BTFL, version: 3.2.0
2018-10-16 @ 19:06:15 -- Running firmware released on: Sep 11 2017 06:43:51
2018-10-16 @ 19:06:16 -- Board: OMNI, version: 0
2018-10-16 @ 19:06:17 -- Unique device ID received - 0x2d00185434570120353232
2018-10-16 @ 19:06:22 -- Connection failed, ensure that you have selected the correct port or restart your device.
Oct 17, 2018, 03:57 AM
That's the Chrome configurator, which I'm not familiar with. You could try the latest version of the standalone BLHeliSuite:
https://www.mediafire.com/folder/dx6...4l/BLHeliSuite
You want the BLHeliSuite16714901.zip file, not BLHeliSuite32_32604.zip.
It looks like this when running:
Oct 18, 2018, 10:46 PM
No Guts, No Glory!
HuffDaddy's Avatar
thanks Bill
Oct 18, 2018, 11:07 PM
No Guts, No Glory!
HuffDaddy's Avatar
does anyone know what the circled cable type is called?
its the cable that runs from the LEDs to the port in these pics...
I want to buy a Y splitter cable like this so I can (without soldering) run a LED strip at the front of the quad off the port...
not even sure if power-wise if that's even doable, hoping it is
Oct 19, 2018, 06:54 AM
I doubt you'd find a pre-made Y lead with those connectors. Normally you'd "daisy chain" boards (so all the LEDs can be individually addressed from BF), by connecting the 'out' pads of the first board to the 'in' pads of the second.
Oct 20, 2018, 02:45 PM
No Guts, No Glory!
HuffDaddy's Avatar
I think this one may be it... and if it is, now its a matter of the voltage I guess... not sure of power requirements for the board that has the LED port but am thinking I shouldn't have to worry about frying (over powering anything ) I am thinking that at worst the LEDs would just not be as bright running 2 off the one port as it is with just one...
not sure if that is an accurate assessment, just my uneducated guess
Nano-JST Y adapter
Oct 20, 2018, 05:30 PM
Should be OK power-wise. But with a Y lead I think your front and back LEDs will both be the same ... which may not be what you want.
Oct 20, 2018, 05:39 PM
I kill batteries!
You can always use a dmm and see what voltage the existing led strip is getting. Since it's a programmaboe strip maybe there's a chance it's got passthrough pads to daisy chain another set but if not you at least know the voltage from a dmm. I'm guessing it's a 5v led strip.
Oct 20, 2018, 07:34 PM
No Guts, No Glory!
HuffDaddy's Avatar
Bill: yaa, I didn't think about the front and back would be the same but you're right... I wonder if I remove the one pin from the connector (not cut it) so they stay all white... when the quad initially boots up they turn on all white for a second or two then change to the color scheme I programmed... hhmm
Crash: whats a dmm?
Oct 20, 2018, 09:40 PM
I kill batteries!
Dmm - digital multi-meter.
News Blade Scimitar 170 FPV RTF & BNF Basic Jim T. Graham Multirotor Drone Talk 23 Mar 17, 2019 12:28 PM
New Product Blade® Mach 25™ FPV Racer BNF Basic ChuckTseeker FPV Racing 829 Oct 27, 2018 10:01 PM
Mini-Review SKYRC SOKAR FPV Racer Review [Unbox, Setup, Flight Test, Pros & Cons] rc808hawaii Multirotor Drone Talk 3 Jul 08, 2016 05:54 AM
Mini-Review DYS X160 Micro FPV Racer Review [ Setup, Flight Test, Pros & Cons] rc808hawaii Mini Multirotor Drones 50 Jun 12, 2016 12:20 PM
Mini-Review EMAX Nighthawk 200 CF FPV Racer Review [UnBox, Assembly, Flight Test, Pros & Cons] rc808hawaii Mini Multirotor Drones 49 Mar 09, 2016 06:46 PM
