How to change motor direction?
Welcome!
I have problem with Rx Turnigy TS4G and Rocket Beast 80A ESC. I can't change motor turning direction. When reverse of throttle is setting at "normal", logging ESC is normal. When I change reverse of throttle in Rx to opposite direction, ESC is not logging. The same with programming card and when changed wires to motor How to change direction? Best Regards LITE |
Make the ESC works correctly first by reversing the throttle channel accordingly to make it forward-brake-reverse as you pull and push the trigger.
Then if the motor spins the wrong way you'll need to swap the motor wires. If it's brushed motor you can swap the polarity. If it's brushless motor (3 wires) you can swap 2 of them, either 2 will be fine. |
Throttle reverse as "normal", wiring as "normal" - log OK, but motor direction is reversed Throttle reverse as "reversed", wiring as "normal" - no logging Throttle reverse as "normal", wiring as "reversed" - no logging Throttle reverse as "reversed", wiring as "reversed" - no logging This is brushless combo: https://www.rc4max.com/zestaw_napedo...574,30659.html |
what do you mean by "log"?
I think LITE talk about starting process.
Most of the time, reverse the throttle on the Tx doesn't work when the motor spin in the wrong direction. Swap the blue and orange wires always works with me. I would try to recalibrate the ESC with the transmitter. The method isn't same as hobbywing esc, but it is ZTW calibration i guess. |
Swapping two wires on a sensored BL system won't work ! Bad things happen, lots of grinding vibration and if you persist something will give , there are a few sensored combos that can't be reversed at all , it should be mentioned in the instructions , but most can be reset to work in reverse by programing them .
It is a sensorless ESC :
Sensored or not if the can timing is sitting at zero the operation should be the same in either direction. I guess I don't understand why logging reverse is important unless someone plans to drive for long periods of time in reverse. Here at work we swap phase wires quite often to keep production going with pre directionally programmed drives . The motors have directional incremental encoders ....much more discrete than basic hall sensors.
At zero on the can i can't swap wires with my sensored motor and ESC, it doesn't work by doing very bad cogging and wires which become very hot. With my sensored combo i change the timing in the ESC not on the motor. I can change the motor direction by changing the parameter in the ESC.
But anyway, here it is a sensorless motor and esc. |
Id think that the "0" timing indicator on the can is not accurate in that case. If timing is truly neutral it shouldn't care. But any who good luck with finding a solution. Have you ever considered that the option of logging reverse may not exist? |
Thank you for interest in my problem. "Logging" means connection Rx with Tx. Motor and ESC are sensorless. With my old "no name" Tx all works properly |
Throttle reverse as "normal", wiring as "normal" - works OK, but motor direction is reversed Throttle reverse as "reversed", wiring as "normal" - not connecting Throttle reverse as "normal", wiring as "reversed" - not connecting Throttle reverse as "reversed", wiring as "reversed" - not connecting |
Thread Tools | |
Similar Threads | |||||
Discussion | How do I change the direction of my servos?? | Dragonaut49 | The Builders Workshop | 12 | Jan 05, 2017 01:10 PM |
Question | Can I Change Motor Direction with BLHelisuite | Glenfilthie | Beginner Multirotor Drones | 3 | Oct 19, 2016 12:53 PM |
Help! | change motor direction (blheli) with arduino standalone | vcazan | Multirotor Drone Electronics | 0 | Jul 21, 2016 09:40 AM |
Help! | How to Change Betaflight/Cleanflight Servo Direction | rymass | Beginner Multirotor Drones | 12 | Jul 19, 2016 07:05 AM |
Discussion | nighthawk pro -motors changing direction at mid throttle | craigb1854 | Beginner Multirotor Drones | 5 | Feb 16, 2016 09:59 AM |
