Aug 02, 2018, 11:40 PM
I Hate Orange Props
MicroPlane6's Avatar
Build Log
AM-40-2 Aldo Montanari OZnoP
I will be building this plane https://outerzone.co.uk/plan_files_0...-40_oz3883.pdf
It will be 138." It is bigger than anything I've built yet, so this should be interesting. I have a Mccoy .35 "Redhead" that I want to use, as I have never flown a internal combustion-driven plane.
I will begin building on the 12th of August. I just wanted to start the thread now, as I will be fixing/testing the engine and wanted to post the process of that as well.
Aug 03, 2018, 12:20 AM
I'll be watched looks like a very interesting build
Greg
Aug 03, 2018, 12:42 AM
I like real wooden aeroplanes!
Sundancer's Avatar
Should be an impressive beast!
Aug 03, 2018, 02:04 AM
B for Bruce
BMatthews's Avatar
That is going to be SOOOOO pretty! ! !
Something you may want to consider is slightly increasing the dihedral. With it as it sits it'll fly just fine. But my spidey senses are whispering to me that it'll be a touch lazy to turn into the high wing when lift tilts the model and you want to smartly turn into the high wing to catch the thermal.
One way to get a touch more dihedral without ruining the look is to make up a building table with a swept up wing tip section that is just curved enough that the top of the wing is straight and the bottom sweeps up to the tip. As opposed to what it is now where the top arches down to the bottom surface in the taper of the tip.
But even with that I'd still sneak in another 25mm's per side to the dihedral.
Aug 03, 2018, 02:18 AM
So I'M meant to be in control?
Colonel Blink's Avatar
That is a model of rare beauty - looking forward to seeing this come together!
Aug 03, 2018, 03:00 AM
who has rabbit ears down
Captain Canardly's Avatar
I'm droolin' here! GG!
Latest blog entry: My "Kubiak" Collection
Aug 04, 2018, 11:41 AM
I Hate Orange Props
Something you may want to consider is slightly increasing the dihedral. With it as it sits it'll fly just fine. But my spidey senses are whispering to me that it'll be a touch lazy to turn into the high wing when lift tilts the model and you want to smartly turn into the high wing to catch the thermal...
It might get some form of roll control. Like air brakes on the underside of the wing that have flaperon control.
Aug 14, 2018, 04:01 PM
I Hate Orange Props
Hacked out a bunch of ribs. I need to get some 1.5, 2 and 3mm plywood somewhere. My LHS has none.
Engine is almost ready for testing.
Aug 15, 2018, 06:26 AM
Won't 1/16" (1.6mm), 3/32" (2.4mm) & 1/8" (3.2mm) do????
Aug 15, 2018, 02:23 PM
I Hate Orange Props
Yup, but my LHS has neither (x)mm plywood or the closest imperial approximations. No plywood at all. What they have is what midwest carries.
Aug 15, 2018, 03:19 PM
That's going to be a beautiful looking plane when built!
It might be worth seeing if you can mail order a quantity of plywood in the common sizes to hold yourself? I try and keep good stocks of ply, balsa, piano wire brass tube etc and then top up when I visit the shows. It gives a nice fuzzy feeling knowing that you have enough materials to build lots of planes - just incase they ever ration balsa wood!!
Aug 16, 2018, 10:23 AM
I Hate Orange Props
Yes, I will be ordering from a distance supplier. I just need to pick one.
Aug 17, 2018, 06:05 AM
Blueplaidcanard flyer
Balsa USA has been good to me for years,nice wood and good people if you need to call them.
Aug 17, 2018, 07:43 AM
rchopper56's Avatar
I'll second that. I used to live in that neck of the woods and found them to be great people!
Gene
Aug 24, 2018, 08:05 AM
Very nice choice - I would have gone for this too!
Discussion OZNoP - Outerzone No Picture Build 2018 BMatthews Vintage & Old-Timer Designs 157 Mar 21, 2019 09:53 PM
Build Log OZNoP 2018, 1935 Curtiss Condor ... Dad3353 Vintage & Old-Timer Designs 242 Feb 25, 2019 03:09 AM
Build Log AM-40 1946 glider Aldo Montanari MaXziim Vintage & Old-Timer Designs 52 Sep 28, 2018 07:52 PM
Discussion OZNoP Flying Wing Captain Canardly Vintage & Old-Timer Designs 14 Sep 26, 2018 07:08 AM
Discussion UFC 194: Aldo vs. McGregor phoam Life, The Universe, and Politics 6 Dec 13, 2015 01:07 PM
