Aug 02, 2018, 07:49 PM
edwen303's Avatar
Question
DIY LED afterburner using brushed ESC?
Having tested Hobbyking 3-color LED ring afterburner systems, older Hobbyking 3/4s powered LED strip, RCGeeks centerburner systems, each has its own advantages and limitations. For one thing, those listed system are not designed for bifurcated exhaust (like in F-15, F-4).
Nowadays LED ring (Angel's Eye for car headlights) rated as 12V or up are fairly inexpensive and are bright. Also have some brushed ESC laying around from older rc models, can't help keep thinking about running those afterburner rings with brushed ESC.
I purchased 60mm and 70mm LED rings from banggood, each comes in pairs with "regulator". Here are the parameters:
60mm ring: outer diameter 60mm, inner diameter 51.5mm
70mm ring: outer diameter 70mm, inner diameter 61.5mm
https://us.banggood.com/Wholesale-Wa...sa-935755.html
Looks like the 70mm ring will fit the twin exhaust for 90mm EDF jets.
Hereafter, ESC for main power = "motor ESC", brushed ESC for LED = "light ESC"
Attempted connecting light ESC and motor ESC with Y-cable, light ESC powered by a small 3s lipo. This setup sounds work: as we throttle up, both motor ESC and Light ESC will increase power level. Brushed ESC will deliver increased voltage and current through the light, which produces brighter light. However I was able to make this work only at the beginning, later trials did not give consistent results. Also tried plug light ESC to channel 6 and set channel 6 as throttle, still not working well.
Here is the older video by Daniel:
home made afterburner for r/c jets (8 min 56 sec)
Aug 03, 2018, 06:40 AM
I don’t know if this would work but...
Can you separate the systems by using a second receiver? Then the lights receiver has its own power supply and the lights esc is treated as throttle.
Aug 04, 2018, 06:16 AM
Registered EDF abuser
Scarey's Avatar
I Have Made one using a brushed ESC for lights and Brushless ESC for Motor. Powered the brushed ESC seperatly with small 3S lipo and used brushed ESC motor wires for LEDs and Y-cable with throttle to both ESCs.
The Jet runs on 12S so LEDs need separate power supply for 12 V operation.
MVI 5772 (0 min 32 sec)
Aug 04, 2018, 09:38 AM
edwen303's Avatar
Originally Posted by JimF
I donít know if this would work but...
Sounds good! Have you tried setting up two receivers, each running its own ESC? Dual receiver seems very common for large RC models, but I haven't tried it myself.
Aug 04, 2018, 11:27 AM
No I haven’t. I’ve just read about guys using separate rx to run accessories like air brakes and lighting
Mini-HowTo Tutorial: How to use a servo board as a brushed ESC or variable brightness LED switch x5252x Electric Power Cars 21 Nov 16, 2016 08:17 AM
Question Using a brushed ESC to control LED brightness w/ DX7 Fredriksson Night Flying 7 Feb 06, 2014 08:44 AM
Discussion Using a brushed esc as a dimmer for led xraydoc Night Flying 6 Feb 17, 2011 05:40 PM
Question Using a brushed esc for dimming control over leds. Bilbobaker Night Flying 30 Feb 17, 2011 05:34 PM
