Dec 09, 2019, 02:53 PM
tware's Avatar
I've been using it in boats, like the Jet Jam, with a Seaking 30A on 3S, albeit it doesn't stay at WOT very long before losing prime and the impeller is tiny, it hardly breaks a sweat. I'll put a watt meter on it, but I'm going to be surprised if it really gets anywhere near 35-40A on the stock prop.
Dec 10, 2019, 01:51 PM
Mineral, VA
tware...please share the link on the cooling jacket that fits the new motor. Looking forward to your test results.
Dec 11, 2019, 01:09 AM
BenVK's Avatar
Is there a more reliable drive shaft available for this boat?
Snapped my 3rd one in a row and everyone is out of stock in the UK anyway.
I intended to buy some flex cable only and repair the broken ones but I can't remove the cable from the shafts. They must have tig welded them or something like that.
Dec 11, 2019, 01:40 AM
tware's Avatar
Sorry, I don't know of a different source, perhaps contact Offshore Electrics or RC Boat Bitz to see if they have a solution? As far as I know, no reports of the shaft being weak another than yours... and 3? Seems like you've got a screw going through the outdrive housing and pressing on the sleeve and/or shaft, or the motor isn't aligned. When you grease the flex shaft, are you leaving a small gap between the outdrive housing and the dog drive? The cable will shorten slightly under load and will snap if it doesn't have a little room to do so.
Dec 11, 2019, 03:35 AM
Don't poke a skunk !!
kartooo's Avatar
i recently bought a Valvryn and looked everywhere for a spare flexshaft and they were out of stock everywhere. finally found one here https://www.lprcs.com/pro-boat-flex-...n-f1-prb282053 looks like they have 1 left...don't know of a source of an aftermarket one either. good luck
Dec 14, 2019, 08:02 PM
Bret Martin
SlickZERO's Avatar
Leopard motor
I wanted to upgrade to the Leopard longer motor however they are 4 mm shaft. The stock motor is 3 mm shaft. Anyone know of a coupler for 4 mm motor shaft that will fit the 3.17 flex shaft?
Maybe drill out the stock coupler to 4 mm?
Dec 14, 2019, 08:33 PM
kartooo's Avatar
lot's of 4mm mtr side here but the cables are measured in inch. looks like your 3.17 flex equals .125 so .130 cable might do it.
https://www.offshoreelectrics.com/pr...+to+.130+Cable
Dec 15, 2019, 09:14 AM
There are more than a few similarities between the Tenshock F1 and the ProBoat Valvryn. I have both boats but have yet to run them (itís winter here). I may have to take some time and determine if the Tenshock shaft will fit the ProBoat. If so, this may serve as replacement for both
http://www.tenshock.com/shaft-for-te...cing-boat.html
Dec 15, 2019, 09:19 AM
HobbyTown states they will have Valvryn shafts back in stock January 2020
https://www.hobbytown.com/pro-boat-v...282053/p789697
Dec 15, 2019, 10:32 AM
Tenshock propeller shaft is a bit thinner and is a model prop for M4 Threaded Shaft.
Dec 15, 2019, 11:47 AM
tware's Avatar
The manual for the Valvryn shows the Tenshocks steering yoke in the illustration. The Valvryn uses a clip, not a clamp with Allen bolt. Just an observation. They did make a lot of changes, to save money it seems.
Dec 15, 2019, 01:00 PM
Bret Martin
SlickZERO's Avatar
Motor coupler
thanks for the information. The stock coupler uses a set screw to hold the shaft. Not sure if there is room for a wrench to tighten the collet type??
I'll have to try it.
Dec 16, 2019, 05:28 PM
kartooo's Avatar
how did you make out with that banggood mtr ?
got ice on your lakes yet ?
Dec 16, 2019, 05:46 PM
tware's Avatar
no frozen lakes here. I couldnt really waterproof or fit the watt meter in the hull as I'd hoped. Need to fix my recovery boat before I start testing anyway. Hoping next week.
Question ProBoat Stiletto Tunnel hull SAVAGEry Racing Boats - Electric 10 Apr 28, 2019 06:40 PM
Help! Looking for Decals for MRP F1 Tunnel Hull Bud Light George Jure Racing Boats - Electric 2 May 12, 2017 11:15 PM
Discussion Dilemma - F1 tunnel hull or catamaran as a fist boat :) goshakv Racing Boats - Electric 68 May 16, 2016 10:49 AM
Discussion F1 Tunnel Hull Laser kit motawold Racing Boats - Electric 3 May 15, 2016 12:16 PM
New Product ProBoat RTR Tunnel Hull Stiletto MarcRacer18 Racing Boats - Electric 7 Aug 06, 2010 02:44 AM
