Dec 12, 2018, 04:44 PM
Nice uniform contour ya got there
Dec 12, 2018, 10:47 PM
nhk750's Avatar
Working on the wing tips installation tonight. Great Planes has you install rectangular balsa pieces then wants you to sand them down to fit...crazy, that is a lot of sanding! So, I traced the shape on the wood with a pencil then cut out the general wing outline from the wood with a keyhole saw, then glued to the wing tip. That will save a lot of sanding later.
Dec 14, 2018, 07:43 PM
nhk750's Avatar
Finished the wing and did a preliminary sanding, the final sanding will be done right before covering. It came out great! Now on the building the ailerons...
Dec 16, 2018, 02:28 PM
nhk750's Avatar
And the fun continues with aileron building.
Dec 17, 2018, 11:31 PM
nhk750's Avatar
Got one aileron finished and the other one on the building board, I will sand the bevels on the LE's and hinge all the control surfaces towards the end of the building process, as I really want to get the fuselage building. For me, building the fuse and engineering the electric conversion is one of the funner parts of the building process.
Dec 19, 2018, 10:43 AM
nhk750's Avatar
Finished up the ailerons last night and now it's time to clean up the build board, and area, to get ready for the meat and potatoes part of the build...THE FUSELAGE! There's a whole lot of control surfaces laying around, waiting for somewhere to go...
Dec 20, 2018, 12:54 AM
nhk750's Avatar
Ready to build Fuse. I needed a white surface under the plan protector for a center line drawn and used some upside down wrapping paper, it seemed appropriate.
Dec 22, 2018, 04:58 PM
nhk750's Avatar
I had to show some progress. Been flying and the holiday stuff is slowing my building down, but I did manage to get the firewall epoxied together. I consists of three light ply parts that you laminate together to form the firewall.
Dec 23, 2018, 12:28 AM
nhk750's Avatar
It's a Christmas miracle, the motor mount I selected (Great Planes large electric motor mount) for the electric conversion fits perfectly on the pre-marked areas in the firewall. That makes me very happy.
Dec 23, 2018, 01:49 PM
nhk750's Avatar
On the flip side of things, here is a great example of "die crunched" parts. The fuse sides and parts are going to need some work after assembly to fill in some crumbling around the edges. As I was sanding and prepping the parts for assembly, they were crumbling around the edges, as expected, for "die crunched" lite ply parts. A little balsa filler and patients and you will never be able to tell.
Dec 23, 2018, 09:09 PM
nhk750's Avatar
Getting some work done today, off work for a few days.
Dec 25, 2018, 12:09 AM
nhk750's Avatar
Getting some formers glued in and thinking ahead on the conversion process. I have a general idea on how I'm going to make the battery hatch on top of the fuse and where the battery tray will go now. It does look that there is a lot of room to work with in this large fuselage.
Dec 25, 2018, 06:18 PM
All Things RC
That fuse frames up quick! You'll be done in no time!
Dec 26, 2018, 11:36 PM
nhk750's Avatar
Had some fun tonight and worked on the power system a bit while the glue dries on stage one of the fuse build. This part of the power system was really easy, I just drilled out some holes in the Great Planes motor mount a little larger, to mount the motor, and set the spacing from the firewall to the rear of the Tru-Turn spinner at 6 1/4" (per instructions), and tightened it all down. When I do a conversion I just mount the motor at the same distance from firewall as the instructions require for a gas motor. I love the GP motor mounts for this as they are so adjustable.
Back to the fuse, I'm seeing this fuse is a little tricky to get together and it looks like gluing the fuse sides in stages is the way to go (per instructions), so I used some Titbond III for the first stage which is the front edges of the sides to the top part. The next step will be to wet the front portion of the sides so you can bend them around the front formers (thats why I used waterproof Titebond III).
Dec 27, 2018, 07:25 PM
nhk750's Avatar
I decided to use epoxy to glue the sides onto the curved formers. The directions do say to use either CA (I always use Titebond II) or epoxy. I figured 30 min epoxy would cure faster and hold the sides better in this case.
Discussion Great Planes 60 size Extra 300s Conversion scott282 Glow to Electric Conversions 23 Dec 27, 2018 11:28 AM
Discussion Great Planes Extra 300s 60 size trident58 Glow to Electric Conversions 5 Nov 29, 2014 02:14 PM
Help! Great Planes Extra 300S .60 size buddek09 Fuel Plane Talk 15 Sep 28, 2012 05:34 AM
Discussion Great Planes 46 size Extra 300 to electric bluefork Sport Planes 3 Sep 23, 2009 12:29 AM
