This thread is privately moderated by blitzen, who may elect to delete unwanted replies.
Jul 31, 2018, 11:03 AM
blitzen's Avatar
The 2S Micro Multi Rotor Build Continues
July 31st. Over the course of this month everything except for the frame, motors and camera had been changed out. The quadcopter has been put together, flown and taken apart a dozen times. This last change was quick and easy. Swapping out the VTX was done to reduce the load current. It worked and the image quality seemed improved too. But, there is a problem. I eventually figured out that the voltage from this new VTX to the camera is now dropping slightly below 5V. And, that isn't enough. Today, Iíll rework that and hopefully everything will be copacetic. If I shot a build video about this, it would be 4 hours long.
Build Log MODDED MICRO MULTIS - Micro Quad Build Log MONOAMORE Mini Multirotor Drones 116 Nov 28, 2017 05:02 AM
Discussion Your Ideas for a Long-range Multi-rotor Build Kubelwagen Multirotor Drone Talk 6 Jan 19, 2016 01:22 PM
