Basher RockSta 1/24 4WS Mini Rock Crawler RTR With Metal Gears
There's a new micro Basher RockSta and it now comes with metal gears. This 1/24 scale crawler is ready to tackle obstacles indoors or out and it is packed with great features that are usually only seen on larger trucks.
New Version with All Metal Gears
There's a new micro Basher RockSta and it now comes with metal gears. This 1/24 scale crawler is ready to tackle obstacles indoors or out and it is packed with great features that are usually only seen on larger trucks. It has a low center of gravity to avoid tip overs and it has 4 wheel steering with multiple steering modes that can be changed at the push of a button on the transmitter. You can steer with the front wheels only, rear wheels only, front and rear opposing, or front and rear together. This gives you a whole range of options to tackle terrain with and allows for cool moves like crabbing with ease.
This is a great looking micro truck with huge suspension travel and fixed diffs making it just like its larger 1/10th scale brothers. It's RTR, but you'll need to provide 4AA batteries for the transmitter and a 2S 300-350mAH lipo battery for the truck to finish it out. The price is listed at just $88.60 making this micro crawler a huge value.
Check out the Basher RockSta 1/24 4WS Mini Rock Crawler RTR With Metal Gears at HobbyKing
Features:
  • All metal gears
  • 4 wheel steering with 4 steering modes that can be switched while driving
  • Motor on axle improve grip on both the front and rear tires
  • LCG chassis design for handling steep inclines
  • Waterproof battery and PCB case
  • Laser engraved metal body
  • Adjustable caster angle
  • 2 in 1 ESC and receiver
  • Uses 2S 7.4V Lipo batteries
  • 2CH 2.4GHz AFHDS 2A Radio with steering mode switch function
Specifications:
  • Height: 95mm
  • Width: 130mm
  • Length: 187mm
  • Wheelbase: 136mm
  • Ground clearance: 28.2mm
  • Weight: 274g (chassis only)
  • Battery compartment: 50 x 30 x 15mm (Max)
  • Radio: 2CH 2.4GHz with steering mode switch function
Jul 31, 2018, 02:37 PM
I've got one already. The weakest link is the servo horn. If you order one, may as well go ahead and order 2 Turnigy 9025MG servos. They're under $10 each.
News Basher RockSta 1/24 4WS Mini Rock Crawler Matt Gunn Rock Crawlers 661 Jan 11, 2020 05:41 PM
New Product Basher RockSta 1/24 4WS Mini Rock Crawler RTR & KIT Jym73 Rock Crawlers 15 Jan 09, 2018 10:24 AM
Mini-Review 1/24 Rock Crawler - Basher Rocksta (RTR version) Teeder Micro Cars 7 Feb 15, 2016 03:09 PM
