Jul 27, 2018, 09:47 AM
nevenelestate's Avatar
New Product
Matek F411-Wing Flight Controller
http://www.mateksys.com/?portfolio=f411-wing
After the awesome Matek F405-Wing FC, they have now come out with a smaller FC designed for fixed wing planes.
FC Specifications
MCU: 100MHz STM32F411
IMU: MPU6000 accelerometer/gyro (SPI)
Baro: BMP280 (I2C)
OSD: INAV OSD w/ AT7456E chip
Blackbox: No
VCP & 2x UARTs
2x Motors, 5x Servos outputs
1x I2C
3x LEDs for FC STATUS (Blue, Red) and 3.3V indicator(Red)
Built in inverter for SBUS input (UART1-RX)
SoftSerial_Tx1: ST1 pad by default
PPM: ST1 pad with softserial disabled
Battery Voltage Sensor: 1:10 (Scale 1100)
WS2812 Led Strip : Yes
Beeper : Yes
RSSI: No
FC Firmware
INAV Flight
Target: MATEKF411
PDB
Input voltage range: 6.5~30V (2~6S LiPo) w/TVS protection
2x ESC power pads
Current Senor: 78A, 3.3V ADC, Scale 423
BEC 5V output
Designed for Flight controller, Receiver, OSD, Camera, Buzzer, 2812 LED_Strip, Buzzer, GPS module, AirSpeed
Continuous current: 2 Amps
BEC Vx output
Designed for Servos
Voltage adjustable, 5V Default, 6V via jumper
Continuous current: 3 Amps
BEC 3.3V output
Designed for Baro / Compass module/ OLED and Spektrum RX
Linear Regulator
Continuous current: 200mA
Physical
Mounting: 24 x 24mm, Φ2mm
Dimensions: 41 x 28 x 10mm
Weight: 7g (Total 12g w/ bottom plate and M2 standoffs)
Reviews on YT
Matek F411-Wing - Part 1 First look and Firmware (24 min 19 sec)
MATEK F411 WING Português - BR (7 min 57 sec)
Jul 27, 2018, 09:53 AM
I have the F405 in a Strix StratoSurfer and love it, but the $50 price tag and large size aren't optimal for smaller flying wings like the S800.
When I saw this one on Banggood I ordered it and when it actually came in I was surprised by how small it is. I am planning on replacing an Omnibus F4 Pro that I am running iNav on in my S800 and installing this FC with iNav 2.0.0RC4.
Jul 29, 2018, 02:42 AM
JulianGoesPro's Avatar
Thanks for creating that thread!
I am still trying to figure out if I even can get:
- vTx control
- GPS + Mag
- CrossFire (CRSF) with TLM
...the lack of blackbox support is something I think I can live without but I don't really want to sacrifice vTx control though that's what I would do.... it's kind of a great idea to be able to launch at 25mw and if needed jump higher so I don't swamp my friends that are already flying and with 25mW...
Unboxing // Matek F411 & F405 Wing FC // iNav (6 min 12 sec)
Edit: just found this... what a relieve
Jul 29, 2018, 07:09 PM
I plan to use the ST1 pad for smart port, on my S800 I don't currently have a SA capable.
Aug 04, 2018, 12:21 PM
F411 Wing target?
I got my new F411 Wing fc the other day.
Plugged it in earlier to flash firmware but couldn't find the F411 target in INav.
Anyone hazard a guess as to what I'm missing?
Aug 04, 2018, 12:56 PM
you gotta look for the F411, matek seams to not differentiate between fc styles but only stm chips with the that fc familiy
http://www.mateksys.com/?portfolio=f411-mini#tab-id-7
Aug 04, 2018, 02:27 PM
ReganATX's Avatar
https://github.com/iNavFlight/inav/releases
Aug 04, 2018, 02:31 PM
lkrustev's Avatar
I am mounting this on Radjet 800. I was surprised it does not power the GPS from the USB. Looks like a great board - we will see how it will work.
Aug 04, 2018, 02:34 PM
ReganATX's Avatar
Anyone know why the f 411 is cheaper than the f405?
Aug 04, 2018, 03:26 PM
Please check specification of both of them. Explains a lot.
Aug 04, 2018, 03:33 PM
Are you gonna "fpv" it ? Will you use 5V camera and vtx ? Or separate battery ?
Aug 04, 2018, 03:49 PM
lkrustev's Avatar
Yes FPV. I think I will power the camera and the VTX from the main battery. Or maybe only the camera from the board.
Aug 04, 2018, 06:25 PM
ReganATX's Avatar
thanks for the explanation
Aug 04, 2018, 06:47 PM
I'm using mobile phone, so i'm limited. Otherwise could do a table, so you could compare it yourself.
EDIT: there you go
Aug 04, 2018, 07:05 PM
Just noticed: you could run both off VBAT. i had an impression, you could be limited to "5V only" camera and vtx. My mistake
Discussion Matek F411 One 30.5x30.5 FC bull0369 Multirotor Drone Electronics 31 Feb 21, 2019 09:12 PM
Discussion New Matek System F411-Mini 20x20mm + PDB mrgilchen Multirotor Drone Electronics 5 Nov 29, 2018 02:07 AM
New Product Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602 nitbeat Multirotor Drone Electronics 26 May 17, 2018 01:44 PM
New Product Matek AIO Flight controller HUBF3-OSD8 (FC, OSD, PDB, Current sensor) blackchatte Multirotor Drone Talk 0 Feb 16, 2017 02:10 AM
