Jul 27, 2018, 02:54 AM
Eagle Tree Vector ESC supported quad x-drone
Is the following ESC suitable to use with Eagle Tree Vector?
Crazepony Wraith32 BLHeli_32 35A ESC(Version 2),3-6S Input Support DSHOT1200 Electronic Speed Controller (Auto Timing Feature, On-Board RGB LED) for FPV Racing Multirotor Drone Quadcopter
https://www.amazon.com/dp/B07CCGSVND...d_w=vyLxJ&th=1
Specifically it is unclear to me if Vector needs or supports like dshot1200 ? Or I'm completely misunderstanding about the ESC?
I'm using T4 (470mm) body for x-style quad drone that is about 1kg category. Is any 4-in-1 ESC possible with the Vector?
Thank you!
Aug 24, 2018, 06:43 PM
tobydogs's Avatar
I to would like to get an answer from someone who is using 4006/620 kv motors like the Tarots. the hobby wing 40amp esc's are simon k and i want to rebuild the tarot 650 sport quad completely and rewire everything 100% including not using the 650 frames built in PDB. I am using the ET Vector as the FC and John from ET says I may be on to the issues my quad is having in flight by changing out the HobbyWing Esc's.
If anyone can help ....Thanks.
