Sep 21, 2019, 01:32 PM
printing problems
hi,
I tried to print a section of the left wing, just to make sure my printer(ender 3) could handle the precision needed for these kind off prints. The biggest issue I have is that my slicer(Cura) removes the structure from the inside of the wing and prints the wing but hollow, making it very weak. Does anyone know what I did wrong?
Sep 21, 2019, 04:09 PM
I had sane problem if i put gcode from zip file It does internal but im not sure It will fit buildplate
Sep 21, 2019, 07:45 PM
3D Printing Maniac
localfiend's Avatar
The G-codes are all sized to fit a 200x200mm build plate, so it'll easily fit on an ender 3.
If you really want to use cura, there's a profile you can download on the thingiverse files section that will make the internals slice properly. I made the profile for the older 3.6 version of cura (which can still be downloaded). Haven't had a chance to see if it'l work on the new version.
Sep 21, 2019, 10:12 PM
How high will it go?
antslake's Avatar
Originally Posted by localfiend View Post
I sent one of these to Peter Sripol so he could do a little destructive airframe testing.
I'm in an area where rockets are a serious fire hazard. Fortunately Ohio has a lot more green stuff, and Peter was nice enough to put it to the test.
https://youtu.be/4PII917Yd-k
That was amazing! Haha. I watch that guy often. Good stuff.
Oct 01, 2019, 12:16 PM
SJ
SJ
SJ's Avatar
Great design!
Just found it 2 days ago, and had to print it.
I Wonder what inspired the design
Its coming along nicely.
It could use a cable tunnel for the motor wires, because of you accidently pull them out, Its going to be a pain to get them back in...... It seems
I think I will stack a few parts together in the slicer if I print another...Im not really using the full capacity of the Tevo Little Monster Delta
Oct 13, 2019, 10:41 PM
FPVObession
Has anyone managed to put a flight controller and FPV gear in one of these?
Oct 14, 2019, 06:09 PM
3D Printing Maniac
localfiend's Avatar
I put the new DJI Digital HD setup in one, flew around great and was a lot of fun. Never bothered with a flight controller yet though. There is a ton of room. Basically the hole nose section is hollow, so you have a ton of room for electronics.
Oct 18, 2019, 11:55 PM
stanordave's Avatar
Printing my second one..
Think I'll use a SunnySky R2308 KV2600 … bit faster and lighter than the GForce I used the 1st time.
Oct 30, 2019, 05:55 PM
FPVObession
I am going to start one with INav, GPS, FPV....
Going to print on a CR10S.
Do you guys recommend PTEG over PLA?
Do you Cura or Simplify3D (I have both)?
Oct 31, 2019, 03:08 AM
Thoemse's Avatar
The beauty of the Pike design is that it works with any filament. It is so rigid that it does not flex with PETG. I made a PETG one and after that one burned down (do not use the recomended setup or if you do dont fly it hard) an ABS one wich is still flying.
Oct 31, 2019, 04:27 PM
HZ Super Cub
Grauwulf's Avatar
What do you recommend for a power system Thoemse?
Oct 31, 2019, 08:59 PM
Ive got a gimbal camera up front, with Pixhawk, Rockblock Sat comms, Landing gear almost done in a 72" scaled version almost done.
Oct 31, 2019, 09:30 PM
Nov 01, 2019, 06:56 AM
Wow...just wow! 72” scaled version WITH landing gear (retracts?)
Can’t wait to see that fly!!
Nov 01, 2019, 09:25 PM
at the moment its fixed, until i find the proper set of retractables for the size of the wing.
Discussion 3D Lab Print - 3D Printed Boeing Stearman northernmonkey 3D Printed Planes 1132 Jul 22, 2023 06:55 AM
Build Log 3D Lab Print 3D Printed Spitfire XVI build Fitz Walker 3D Printed Planes 13 Jun 14, 2017 03:44 PM
Discussion 3D Lab Print 3D Printed Spitfire XVI Power povlhp 3D Printed Planes 5 Jun 04, 2017 05:17 AM
Discussion Where to run 36" fast electric boat in northern il ramman347 Dock Talk 2 Apr 30, 2017 07:18 PM
Build Log The Cuda's Bigger Brother... The Cuda Para-Noia mudman1959 Foamies (Scratchbuilt) 2 Apr 27, 2016 09:50 AM
