Jul 24, 2018, 04:43 AM
Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module
Hi all, the Jumper T12 is now being officially announced. Pre-production samples are just about ready to ship out to testers and reviewers. Official sale date TBA. RRP $89.90
Official Jumper Website
Follow us on facebook
Wholesale & Dealer enquiries
Thanks!
Hobby Porter Team.
The Jumper T12 brings the best features of the T8SG v2 series and bundles them together with JumperTX an open source Firmware set based on the OpenTX Project. Compatible with JR style RF modules the T12 comes with the JP4-in-1 Multi protocol module as standard
You asked, we listened.
One of the most asked questions when the T8SG v2 was release was will it work with TBS Crossfire. We are happy to announce the T12 version does indeed support Crossfire and in CRSF mode with LUA script support and most importantly WITHOUT any hardware modification for end users. If your looking for the most compact, most affordable and most EPIC Crossfire compatible TX in the market today look no further than the Jumper T12. Jumper is committed to supporting OPEN hardware module platforms and will never try to force customers on to proprietary equipment.
Keep it simple, keep it affordable.
The T12 platform is shipped with the JP4-in-1 Multi-protocol module. If you already own JR Modules such as the TBS Crossfire or any other JR Module compatible 2.4ghz, Analogue or Long Range UHF system the T12 is ready to rock out with its socket out! A standard LCD screen was used along with the T8SG V2 butter smooth V2 gimbals offering quality, usability and best of all affordability.
Goodies included
The T12 comes standard with a neck strap and AA battery tray. The T12 can also be powered with any LiPO or LiFE battery of a compatible size meaning users do not need to source their own uncommon sized Li-ion round cells or a round cell charger.
Seamless Integration
The T12, when paired with the Jumper JP4-in-1 offers seamless intergration between JumperTX (an open source Firmware set based on the OpenTX Project) and module meaning protocals can be accessed and selected directly from the software GUI. Crossfire users can setup their equipment via LUA scripts
Radio Features:
JR/FrSKY compatible module bay on rear side (module not included)
USB online firmware upgrade
Ultra-low power consumption, longer battery life
Channels: up to 16 channel output
Wide voltage input (2s lipo recommended)
Multilingual menu
Vibration reminder function
Support telemetry (depending on the receiver)
Crossfire CSRF Compatible: Yes
LUA Script support: Yes
Radio Specs:
Radio MCU: STM32F205VET6 (512kb)
Size: 158 * 150 * 58
Weight: 342g (without battery)
Working voltage: DC5-DC9V (factory with 4 * AA battery box, 2s Lipo recommended, batteries not included)
Firmware: OpenTX
Display: 1.7-inch LCD display, 128* 64 resolution
Gimbal Type: Potentiometer
Upgrade method: USB online upgrade
Simulator mode: 3.5mm standard ppm output or USB HID
Voice support: YES
Jumper JP4-in-1 Module
The Jumper JP4IN1 Module features the CC2500, NRF24L01, A7105 and CYRF6936 RF Chip modules all integrated on one board. This module can convert standard PPM signals form module equipped radios in to the RF protocols used by most radios in the market today (See RF Chip data below). This module is plug and play with module equipped radios in the FrSKY series and requires no complex wiring or “hacking” to get running. The module is a great way to improve the enjoyment of your flying experience, using a better radio such as the FrSKY Taranis series rather than the low grade radios commonly included with most kits offers an night and day difference in performance. The Jumper JP4IN1 module is also upgradable via USB input
JP4-in-1 Specifications:
Working voltage: 6-9v
Working current: <=100ma
Operating frequency: 2.4G ISM band
RF power: +22DBM
Main control chip: STM32F103CBT6 (128K ROM, 20K RAM)
Module bay compatibility: FRSky, Jr and other dimensions: 64*49*33 (without antenna)
Net Weight: 42g (including antenna)
Software Compatibility: Suitable for radios using OpenTX or er9x/ersky9x
Firmware updatable: Yes, via USB.
RF Chip Data
Cypress Semiconductor CYRF6936: DSM/DSMX, Walkera Devo
Texas Instruments CC2500: FrSky, Futaba SFHSS
Amiccom A7105: FlySky, FlySky AFHDS2A, Hubsan
Nordic Semiconductor NRF24L01: HiSky, Syma, ASSAN and most other Chinese models
OpenTX Firmware is developed by the OpenTX team. Full credit is given to the developers of OpenTX. Please visit http://www.open-tx.org/ to learn more
Final specs are subject to change.
Jul 24, 2018, 06:12 AM
Main control chip: STM32F103CBT6 - I assume, this is inside the module.
But what is inside the transmitter, I mean the main chip running OpenTX - model, speed, memory?
Also, do You plan to release "Plus" version with Hall gimbals?
Jul 24, 2018, 06:17 AM
I assume they want to save money by reusing the same crap design shape although the programing roller/dial is a must in a 12ch Tx
Jul 24, 2018, 06:40 AM
Inside the module are 4 RF chips, you have them listed right above your post. Cyprus is Cypress, typo.
STM32F103CBT6 should be the CPU that is running OpenTx, same family, but less capable than in Taranis.
Jul 24, 2018, 06:51 AM
I don't think so. This is too small a CPU (low on memory and IO pin count) to run a quite big OpenTX firmware, unless it's much trimmed down.
And the part where it is mentioned is a direct quote from 4-in-1 module specs.
Taranis is running on F2 family with at least 2 times bigger memory and more IO lines.
Jul 24, 2018, 07:25 AM
so no hall effect gimbals or oled?
Jul 24, 2018, 08:00 AM
Hi all, thanks for the input and questions. The Radio its self uses an STM32F205VET6 (512kb).
Jul 24, 2018, 11:02 AM
Kambalunga's Avatar
The FCC ID is 2ANTI-T12 but the odd thing it's only for the CC2500 part. The other three transeivers are supposedly deactivated.
Jul 24, 2018, 12:13 PM
they did the same thing when certifying the deviation version of the tx.
Jul 24, 2018, 12:19 PM
Afaik T12 doesn't have any transmitter chip inside. You need to have a transmitter module plugged in (4-in-1 or other JR-compatible)
Jul 24, 2018, 12:29 PM
Kambalunga's Avatar
So the Jumper JP-4 has no FCC approval?!
Jul 24, 2018, 12:55 PM
I just realized that the 4 in 1 was on a module, not built in. that's disappointing.
Jul 24, 2018, 02:52 PM
Why ?
Jul 24, 2018, 03:16 PM
because it is one more thing to get lost, stolen, needed to be updated, etc. also if you frequently fly with and without a lr system you'll be constantly swapping modules. and I'd probably forget it somewhere and not realize it until I need it.
Jul 24, 2018, 03:17 PM
it also looks like it doesn't have voice, either.
Discussion New version Jumper T8SG Multi-Protocol 10CH Compact Transmitter with 4 in 1 module YSeph Radios 1508 Jan 29, 2020 09:05 AM
New Product 4 In 1 RF Module With Case (Multi Protocol) [JR, FRSKY, Futaba] nitbeat Radios 21 Aug 25, 2018 06:23 AM
Alert Jumper T8SG Multi Protocol Radio $69.99 fastmax Radios 0 Jan 15, 2018 05:13 PM
