Sep 16, 2019, 04:18 PM
3 wire servo
This may have been posted already but the Hextronik HXT500 3 wire servo is an exact fit for the lt832 if upgrading the electronics. Just trim off the mounting tabs and good to go. The stock servo saver fits also and is the same spline. When installed it may seem loose towards the rear but edge it forward and the cover has a rear lip that keeps it in the perfect position.
Sep 17, 2019, 12:56 PM
Better view of LapTrax in action:
LapTrax timing a JJRC LT832B (0 min 46 sec)
Sep 17, 2019, 05:08 PM
Very nice!
Sep 17, 2019, 07:34 PM
ultra cheap pilot
ican3d's Avatar
I might need to get myself a laptrax too
Sep 18, 2019, 02:00 AM
LapTrax works great and it's free - very impressed. It can also track colour to time multiple cars.
Dead happy with the buggy handling now (finished modding); I can just focus on getting used to the steer wheel and thinking of ways to knock up indoor tracks that are interesting and very quick to assemble/disassemble. The rope didn't work out as my daughter getting getting the car stuck!
Sep 24, 2019, 04:09 AM
Fan of just about anything RC
SoloProFan's Avatar
Sounds good. Any pictures of the servo in place? Does it need any mounting stuff like double face tape or just press fit?
Edit: If I understand correctly, the cover that is screwed onto the frame, holds the servo on the spot, right?
Sep 24, 2019, 05:40 PM
The servo needs no tape, it fits perfectly. It seems loose until you pop the cover on which holds it exactly where it should be positioned.
Sep 24, 2019, 07:36 PM
Servo clarification
[tIf I understand correctly, the cover that is screwed onto the frame, holds the servo on the spot, right?[/QUOTE]
The above listed servo I mentioned is a direct fit for the LT832. The servo saver of the LT832 fits . It does NOT fit a Losi micro T servo saver. A 5 wire replacement Micro T servo does NOT work in the LT832. The electronics are apparently different and does nothing when installed in the LT832. The spline on a micro T servo is much smaller than that in the LT832 also. Anyone using the stock 5 wire servo that may go bad do not buy a Losi 5 wire servo, it won't work.
Just wanted to mention so no one tries, Like I did.
Sep 25, 2019, 04:01 AM
SoloProFan's Avatar
Hmm, sounds like this winter I should finally pick up upgrading my JJRC 1:32 cars. I did get the WL Toys "brick" but never got to installing it. Best source for the HXT500 seems HobbyKing, right?
Latest blog entry: For the love of the hobby!
Sep 25, 2019, 06:45 AM
I purchased mine at amazon, US was next day shipping. While your working on it make sure that you remove the motor screws and put thread lock. I have two and both didn't make one battery through them until the motor screws loosened and came away from the spur gear almost destroying the teeth. Thread lock will keep it locked in.
Sep 30, 2019, 04:36 AM
SoloProFan's Avatar
Ordered a few servos from HobbyKing, added some NiMh AAA to make most of the shipping fee. I will thread lock motor screws, thanks for the warning.
Yesterday, 04:35 AM
SoloProFan's Avatar
Got the servos a little while ago, but then disaster struck, and we had to escort my dad to go to his final resting place...
He would have loved to see this car run through his relatively large open area living room, but that is not going to happen. But while the rent on his former home still hasn't been canceled, it would be some sort of tribute to still at least run this car there one more time, after being fixed. So I will continue the conversion to WL Toys electronics, and see how it goes.
Today, 02:00 AM
SoloProFan's Avatar
The HXT servo fits ok, after trimming mounting tabs naturally, but was still a little loose on the side and rear. I used a few trimmed bits of dense foam to really secure it. I also mounted the WL Toys board in reverse, so the wires coming from the switch at the bottom, fit without having to extend anything.
I re-used the plastic electronics cover, after trimming some parts of it, to accomodate the new electronics board.
Today, 10:25 AM
servo
So sorry to hear about your dad, finish the conversion and you will serve his memory every time you take it for a spin. As far as the servo it is slightly loose but once I put on the top cover it was very tight fitting and secure. Keep us posted on the final outcome of your mod and my regards to the family.....good luck..
Review Hobbico's Dromida 1/18 Wasteland 4WD Truck and 4WD Buggy RTR Combined Review Michael Heer Off-road Cars 6 Feb 26, 2016 04:18 PM
Help! Turnigy 1/16 4wd Nitro-T Truggy w/ .07 Engine (RTR) Bones12 Nitro and Glow Power Cars 3 Feb 05, 2016 02:54 PM
Alert Thunder Tiger - ST-1 1/8th 4WD Nitro RTR Stadium Truck bluekite Nitro and Glow Power Cars 1 Mar 10, 2006 02:59 PM
