Jul 23, 2018, 09:44 AM
New Product
Caddx Turbo Micro F2 (w/ mic) and S2 (w/ turbo eye lens)
Caddx Turbo Micro F2 1/3" CMOS 2.1mm 1200TVL 16:9/4:3 NTSC/PAL Low Latency FPV Camera W/ Microphone
F2 has mic added and is 1g heavier than F1
Caddx Micro Turbo F2 manual, click here
Caddx Turbo Micro S2 1/3 CCD NTSC/PAL IR Block Low Latency FPV Camera w/ Turbo Eye Lens
Features:
* Upgraded Turbo eye lens
* PCB protection
* Integrated OSD
* 1/3" CCD Sensor
* Global shutter
* Low latency
* Voltage detection
* Wide voltage range
Caddx Micro Turbo S2 manual, click here
Aug 13, 2018, 08:53 PM
I can't get the mic working. Everything else works except audio. Can someone help me? Thanks
Aug 21, 2018, 09:47 PM
I have the SAME exact issue, and it’s on two cameras I bought.
I suggest this guy respond to this post or we’ll start dropping bad reviews on this camera
Aug 22, 2018, 08:01 AM
If you meant me, i'm not a caddx representative nor do i have anything to do with them. I also ordered f2 camera but it hasn't arrived yet. Ordered bit later and it should arrive soon so i'll see if i have same problem
Sep 02, 2018, 06:00 PM
My turbo micro f2 has a horrible dark/light/dark transition. To the point I am not using it. WDR is on... anyone have any other pointers to get it usable?
The turbo micro f1 seemed way better out of the box (from watching other people use it in the field). Pretty disappointed so far.
Sep 20, 2018, 07:15 AM
Pedrusko's Avatar
Tested my f2 at home and noticed the same. Performs well with low light, but if you look outside from a window, even if it's at shadow, whiteness overwhelm the image.
Good for a plane or wing, very bad if you pretend to fly a race or freestyle quad.
Sep 20, 2018, 08:24 AM
Yeah, I've tried changing the brightness, contrast, white balance (to global) but nothing helped.
Oct 26, 2018, 10:47 AM
Soldering required
humayraykinaon's Avatar
I wish I've seen/read this thread first before buying the f2 cause I get very bad picture outside (more reddish) but much better picture when inside the house.
Nov 06, 2018, 11:28 PM
Soldering required
Little update: I've had a light crashed and the quad went upside down and now my lens has this dirt in the center, don't know how it got in but whatever, then I remember I have a spare micro swift lens 1/3 2.3mm so I put that in and I like it better than the original lens.
Feb 11, 2019, 06:20 AM
Fan of microElectroRfIT
what are the best settings for the F2.? can anyone share please ?!
having issues with audio as if there is no audio.
something is wrong with this board.
Discussion Caddx Micro Turbo S1 2.1 / 2.3MM 600TVL 4:3 1/3 CCD NTSC / PAL scousethief Vendor Talk 5 Jul 07, 2020 03:01 PM
Discussion Caddx Turbo micro SDR1 Super WDR FPV Camera BobFromMars FPV Equipment 51 Apr 25, 2019 09:13 PM
Mini-Review Caddx Turbo Micro F1 1200TVL Micro CMOS FPV Camera kremerFPV FPV Equipment 13 Aug 10, 2018 10:44 AM
