Jul 22, 2018, 09:44 PM
what is the current FPV VTx/VRx for long range planes?
I have to put this thread hear, not in FPV equipment:
Hi, I'm looking to buy a VTx/RTx for my FX-61 in order to get long range FPV.
What are the options on these days? I look for Lawmate, but I don't know if it is the best options. It was 2 years since my plane was build and I'm not sure what the options are today.
I'm thinking on these items:
https://www.readymaderc.com/products...r-intl-version
https://www.readymaderc.com/products...-comtech-tuner
https://www.readymaderc.com/products...m-antenna-rhcp
https://www.readymaderc.com/products...r-antenna-rhcp
how far will I get with them?
Thank!
Jul 23, 2018, 02:35 AM
fly by night
BCSaltchucker's Avatar
none of your links work
the Fox800 vtx were the go-to vtx 5 years ago for this.
your range will depend mostly on your antennas, not on vTx choice. Range could be well under 1km with bad antennas or 150km with the right combo of antennas
Jul 23, 2018, 11:35 AM
Daemon's Avatar
FOX 800 is still the go-to long range VTX, and the rest depends on your choice of
VRX, VRX antennas, having the right airframe,LRS, proper gear installation, planning, and
building lots of experience. No combination of gear will magically give you 100km range
on your first try. 99% of FPV pilots who have long range equipment still never fly more than
10-20km out.
Jul 23, 2018, 01:56 PM
Officially, long range does not exist
Jul 23, 2018, 03:08 PM
Thank! I fix the links.
I was flying 5-10 Km with my skywalker. I have a drgonlink and Chinese 1.2GHz Vtx and Vrx.
Now I have an Fx-61 and want to go 20/30 km. But if I have to buy some equipment it would be nice to buy equipment that allows me to go far in the future.
is FOX800 this?
what do you think about my links?
Jul 23, 2018, 03:19 PM
or maybe less power Vtx but more antenna gain:
https://www.readymaderc.com/products...k-edition-intl
https://www.readymaderc.com/products...c-antenna-rhcp
I think that 50km is the longest distance that I want to reach...
Jul 23, 2018, 05:52 PM
Are we not men? We are DEVO!
xanuser's Avatar
Everyone needs to watch Bruce's (rcmodelreviews) new vid on rf power/gain
Jul 23, 2018, 07:35 PM
Ok, that's totally true. It will be better a 1.2GHz and 800mW on my mid-size flying wing than a big 2.5W transmitter.
So the question now is what pair of antenna do you suggest for 20-50 Km? Peperbox, biquad, helical on the VRx and what about on the VTx? A dragolink dipole? a "Vee"a Cloverleaf ?
Thank
Jul 23, 2018, 07:37 PM
xanuser's Avatar
you will get many opinions. im partial to pagodas and helical.
Jul 24, 2018, 04:04 AM
The 5.8G 600mw transmitter plus high gain antenna can exceed 20km. If using a 1w transmitter, it can exceed 30km
This video shows a 1w transmitter with a receive antenna gain of 14dB for long distance flight
楓葉天線 (Maple wireless) 5.8g 14DB Flat antenna RX & 5.8g 1000mw TX 22.2km distance test (4 min 43 sec)
Jul 24, 2018, 04:12 AM
According to the accumulated experience, the fpv image transmission distance is no longer a problem. Whether it is 1.2G or 5.8G transmission distance can meet the requirements, but the 5.8G system has smaller devices and antennas
Jul 24, 2018, 11:07 AM
fly by night
furthest I have seen a 5.8G system go is about 38km, but with horribly unreliable image at that range using carefully tuned helical
furthest I have seen a 1280 system go is about 130km, with decent-enough quality image
there is a vast difference the long range performance of 5.8band vs the 1.3G band. larger waves just penetrate better and less affected by atmosphere and objects. Though I have been using 5.8G mostly for the last few years as the antennas have gotten much better (and I am not going long range much). If I want to go over 10km, I would always go to 1280mhz, it's just easier for doing it.
also have to get serious about your UHF RC radio antennas when going over 20km IIRC. and then both the video recevier and RC Tx antennas all have to be directional, carefully aimed and coordinated with your telemetry
Jul 24, 2018, 11:09 AM
Daemon's Avatar
FWIW FOX800 (measured 610mW) 1.3Ghz has been out over 160km with dipole and 15dB Yagi
https://fpvlab.com/forums/showthread...l=1#post671323
Jul 24, 2018, 11:29 AM
Thank to all for your comments
Could someone point me out into a link to a FOX800, please?
what kind of anntena do I need to use on the plane if I use this on ground?:
Thank!
Jul 24, 2018, 01:56 PM
Daemon's Avatar
Any/all 1.3Ghz VTXs with an 800mW rating, is a FOX800. It may be referred to
as a Phartom or whatever, but they're all the same VTX (other than the US versions which
are locked down to only 2 channels). Sometimes you'll see it with a large case which is
meant to act as a heat sink, and sometimes without. Again, same VTX inside, and we usually
use them without the larger case. One full side exposed to direct outside airflow is
all it needs to not burn up.
With a CP VRX antenna like that you'd probably use a Airscrew Ultra or Singularity (although
I still haven't seen the Singularity used at extreme ranges yet).
Discussion recommend a small and stable plane for long range fpv? ahtiram FPV Aircraft 10 Feb 24, 2019 09:59 PM
Discussion what is the current FPV VTx/VRx for long range planes? elgarbe FPV Equipment 7 Jul 23, 2018 07:15 PM
Discussion Best Plane for Long-Range FPV and GPS ReviewEdge Electric Plane Talk 12 Jul 22, 2017 12:30 PM
Question What's the ideal airfoil for long range FPV? keffe1 The Builders Workshop 10 Jan 29, 2016 05:25 AM
Question What Are Some Of The Best Video Tx/Rx in 1.3ghz To Use For Long Range FPV? superjon FPV Talk 26 May 16, 2013 09:45 PM
