| Thread Tools |
| This thread is privately moderated by RightBrother, who may elect to delete unwanted replies. |
EPP Scratchbuilt Delta Wing
Not quite finished, needs a couple of hatches made but it is functional and ready for maiden which I could do tomorrow but will probably wait to get a headmount for my phone camera to take videos. CG is back about 23 cm and had to use a little ballast to get it to balance. Could use a much heavier motor and/or battery with more thrust - this little motor gives about 1:1 but the lift should be awesome as the AUW is 340 grams. I added some tape covered skids on bottom to protect fragile leading edges and to keep motor mount from digging into ground.
If it flies nice I might try faster prop rather than this slowfly prop, and add a rudder with 5g servo. Also could go with a bigger motor. Excited to fly it but am thinking about my next project already which will be a scratchbuilt hotliner using same 5mm epp foam and fishing pole tubes and just elevons with only a vertical tail. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| New Product | FTC HUNTER 680mm wingspan EPP Delta wing | Andy852 | Flying Wings | 23 | Oct 05, 2019 02:38 PM |
| New Product | FTC HUNTER 680mm Wingspan EPP Delta Wing | Andy852 | FPV Aircraft | 2 | Nov 13, 2017 05:32 PM |
| Help! | Scratchbuilt Delta wing help | ggradtech | Flying Wings | 0 | Sep 25, 2013 09:17 PM |
